ABS code 31
jruppert
294
Michigan
I was making some changes today on my intake tubing that led to my Pro-M meter. Once I was done with my changes I went for a drive and my ABS light came on. This is the code that I got...31 Right front anti-lock brake sensor continuity fault Go to Pinpoint Test B1.
Are there any wires I may have broken when messing around with the meter? There is a thick harness (bout 1 inch diameter) mounted to the sheet metal directly under the meter. I did move this wire around. I have gone back to look to see if anything was disconnected and have found nothing. Any thoughts? thanks
Maybe while you were moving the harness around, not knowing the wires were brittle, you may have "stripped" or "broke" a wire and not even known.
I would go back and inspect the harness, the best you can, and look for any broken or bare wires. That's what it sounds like to me...
