(ABS) light?
BigTom69
I have my ABS light on. My light would come on and off and so would the trac button. Now I changed the breaks all around and the light is still on. DO a ABS light code stay there or something or is something else wrong. No when its on I can't turn the trac button off. Would you guys know of anything that would cause this? Thanks
Well the ABS and Traction control are the same system, so if the ABS doesn't work neither will the T/C.
If you just did brakes, perhaps you dislodged or damaged a wheel sensor.
Yes the ABS will throw codes, but you can't read them. Will need to take to Ford.
Most likely it will say a faulty wheel sensor anyway
