ABS Sensor wire ?
rabidscoobie
616
12
48
College Station,TX
Ok most all know I just bougth the 04 mach,This past weekend I pulled the tires off to check everything out behind them,you know brakes and what not.Well I noticed that on the front passenger side the ABS sensor wire has been rubbed by something right behind the wheel,it has a small amount of insulation worn.I dont know if this might be something from the previous owner or what.Im not getting any CEL or ABS lights its just something Ive noticed,any ideas what could possibly be rubbing if that is the case.Its got factory Black buliits with Fuzion 275/40/17's on them...thats what it had when I bought it,when those are worn ill be putting some BFG's on there.If I cut the wheel sharp in either direction it doesnt look to be hitting hit so it may be nothing to worry about.
