  • 1994 - 1995 Specific Tech
(ABS)?
  • Thread starter Thread starter 94pony
  • Start date Start date Sep 13, 2004
94pony
151
Arlington, Tx
Sep 13, 2004
  • Sep 13, 2004
I just replaced all four rotors with new ceramic pads all the way around.
The problem I am having is my ABS for the most part is not working. The light stays on. But sometimes the light is not on and the ABS works. Anyone have any idea's??????
revhead347
Apparently my ex-husband made that mistake.
20+ Year Stangneter
Jun 14, 2004
9,303
1,649
214
Acworth, GA
Sep 13, 2004
  • Sep 13, 2004
If you bleed the brakes when you change the brake pads, you need to unhook the battery, so that the ABS unit doesn't transfer any fluid. If it does, then you can get air bubbles in the lines, and regular bleeding won't get them out.
Kurt
maypo59
194
Central Kentucky
Sep 14, 2004
  • Sep 14, 2004
Or, you had some air trapped in your lines, and when you compressed the caliper pistons, you pushed it into the ABS valve.. bad. can't be fixed by just bleeding the old fashion way. It needs to be bled with a special tool in place to open the ABS valve while bleeding. If you can't find any other cause, like that you disturbed a sensor or something, you should (hate to say it) take it to Ford or a brake shop and have them FLUSH it. Since they are going to charge the crap out of you anyways, don't just get it bled, get all new fluid in the system
94pony
151
Arlington, Tx
Sep 14, 2004
  • Sep 14, 2004
I just changed the brake fluid myself about six months ago. My guess is just to try reseting the system. I shall let you guys know..... Thanks
Brake pad and rotor upgrade
  • Sparky714
  • Aug 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Sparky714
All power lost at crank
  • saf_blu302
  • Mar 7, 2026
1994 - 1995 Specific Tech Mar 12, 2026
General karthief
M
Electrical lights
  • Magnet86
  • Sep 11, 2026
Fox 5.0 Mustang Tech Sep 14, 2026
Magnet86
M
D
Speedo and tach dead
  • Davinrobinson1
  • Jul 19, 2026
1994 - 1995 Specific Tech Jul 26, 2026
fasterthangas
F
L
05GT brakes on a 98GT?
  • lparsons42
  • Sep 6, 2025
1996 - 2004 SN95 Mustang -General/Talk- Sep 6, 2025
lparsons42
L
