AC compressor 02 GT
Mine leaked at 31,000m. Was replaced June 2010 and is leaking oil. I missed the 12-12 warranty and have to buy it again. Has less than 1000m on it. It was put on at a dealer. Replacement unit was a rebuild one and the next one will be a rebuilt also. How is your experience with refurbished AC compressors?
No experience with refurbished, but I have tried a couple j-yard compressors. The first one lasted about a month and locked up. I was fed up with trying to fix the system after a leak at the condenser and a couple leaks in hoses. This summer, I bought a 200k mile compressor from the j-yard for another 30$, evacuated and filled the system with twice that cost in freeon and it worked great all summer long. Considering hot terrible this summer was, I am satisfied already.
Just wondering, did anyone replace the orifice tube, receiver/dryer, and flush the coils before installing the new/rebuilt/salvage compressor?
The need to do this work depends upon how the previous compressor failed. If the compressor fails in-service, the oil will be contaminated. If not completely removed, this may cause the service life of the replacement to be short.
You seem to be going through compressors quickly....
May I suggest that you do the work yourself this time?
I don't trust anyone but myself to do work on my car and wouldn't put it past a technician to either forget or simply neglect to evacuate the system after putting on the new compressor.
Water in your PAG oil will kill your system quick. When you put a vacuum on the system (and it holds steady for a few minutes) the extreme low/no pressure causes any atmospheric water vapor to crystallize and freeze and will be pulled out of the system.
You can do this yourself with a rental vacuum pump from auto zone.
I replaced a hose on my A/C system and saved hundreds of dollars by doing it myself.
I would strongly encourage you to inject UV dye into the system when you refill the refrigerant. I don't know how much to add, but check on the PAG oil as well, it is necessary to keep the system lubricated.
Not sure what was done. It still blows very cold air. Just has a film of oil on the bottom of the compressor. It was rendered "leaking oil"
I would if I could. Not something I want to deal with. But thanks for the info.
