  • SN95 4.6L Mustang Tech
AC Compressor
  • Thread starter Thread starter FEARED
  • Start date Start date Apr 8, 2005
FEARED
...but won't that hurt you?
Apr 1, 2005
29
Valley of The Sun
Apr 8, 2005
  • Apr 8, 2005
Hey Guys,
I've had some rattling noise in the engine compartment and traced it back to the AC compressor clutch and pulley assembly. There is a plate thats about a 1/4" in thickness and is vibrating like mad. I attached a pic of the what I'm talking about. Any idea how to correct this? I havent touched an ac compressor in 10 years.
FEARED
Apr 1, 2005
29
Valley of The Sun
Apr 10, 2005
  • Apr 10, 2005
Common. I know someone can help me out here.
5.0's 4 ever
The #1 Stunna
5,794
Orlando, FL
Apr 10, 2005
  • Apr 10, 2005
Looks and sounds like you need a new ac clutch hub, thats the plate on the front of the ac compressor that you are talking about. I would take off the nut, pull of the plate, inspect the clutch pulley surface also for excessive wear. If it looks fine, replace the clutch hub, but make sure you put the clutch air gap to spec. The original shim will usually put you in spec but I would check to make sure with a feeler gauge that its around the .021-.036 inch range when assembled.
FEARED
Apr 1, 2005
29
Valley of The Sun
Apr 10, 2005
  • Apr 10, 2005
Thanks for the reply. I will check it out next weekend. Hopefully it will be a pretty straight forward fix. I may post again if I f it up.
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
M
  • mnky99
  • Sep 5, 2025
mnky99
M
Fox Suspensión Noise
  • PonyGTrider
  • Nov 24, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 8, 2026
PonyGTrider
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
Engine Motor swap from a 2003 Explorer
  • 1996mustang new
  • Oct 9, 2025
SN95 4.6L Mustang Tech Oct 16, 2025
squeak93
