ac/heater expertise please
ok, im having a bit of a problem with this. searched and read some people say if there's a break in the ac syst. moisture ruins the ac accumulator/drier and you need a new one----is this true??? 2nd question is--how do i get the bottom silver connector off the evap core--do i need a special tool??. thanks
1) Yes. The desiccant (yes, I spelled it right) becomes saturated from the ambient moisture in the air and cannot absorb anymore. You can get new ones at a decent price from acsource.net.
2) Same tools that you use to disconnect the fuel lines. Any auto parts place will sell them. I bought a plastic assortment from Autozone for about $3. Title is "A/C and Fuel Line Disconnect Tools".
I agree....but it should be ok if you are just doing a repair and it isn't disconnected for too long and you cap the ends. Also sometimes the spring inside the springlock gets corroded and doesn't want to roll off the flare of the female springlock, don't worry it will work loose after a little finesse. Also replace all the o-rings before re-assembly. Good Luck........
