  • 1994 - 1995 Specific Tech
ac help
  • Thread starter Thread starter paxton86
  • Start date Start date Jul 30, 2006
P
paxton86
38
  • Jul 30, 2006
Finally got around to replacing the vacumn line that controls which vents the ac blows out of.
i tried using a soft connecter and a long peice of vacumn line, connected to the old line, hoping i could just pull the old peice from under the dash, attach the fittings to the new line and be done. as i was pulling the old peice snapped, so now im lookin for an easy way to get the line back through the firewall. i cant see well enough from under the dash to feed it into the engine bay, and i the foam is kicking my a** trying to go from the engine bay to under the dash....
thanks guys.
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Jul 30, 2006
  • Jul 30, 2006
Would it be easier to run a new rubber line through the hole in the firewall where the main wiring goes through, then run it under the dash? Many people cut the rubber gromet to run amp wiring and it will at least get you to the other side of the firewall.
What I did was use some 1/8" i.d. rubber vacuum line and stick the remaining plastic hard line inside the new line and tape it off. I think 1/8 i.d. should be very snug and not cause any further problems.
Scott
Scott
P
paxton86
38
  • Jul 30, 2006
didnt even think of that. thanks
D
AC Circulation
  • Dtn520
  • Jun 26, 2026
  • The Welcome Wagon
The Welcome Wagon Jun 27, 2026
LILCBRA
U
No fuel pump relay in harness
  • Uli661
  • May 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 1, 2026
Uli661
U
A/C blowing defrost
  • 70/04mach1
  • Jul 20, 2025
1996 - 2004 SN95 Mustang -General/Talk- Jul 21, 2025
A
Catch can questions.
  • AngryH58
  • Sep 26, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 29, 2026
squeak93
F
Electrical Foxbody wiring harness 2.3 to v8 swap
  • Foxbodyjake
  • Mar 23, 2026
Kleinjj27
K
