  • 2005 - 2009 Specific Tech
AC not cooling that well
  • Thread starter Thread starter tonylentini
  • Start date Start date Jun 14, 2006
T
tonylentini
  • Jun 14, 2006
Hot weather and I noticed my 2005 GT's AC is not cooling well. Mornings it is okay, but when it is really hot outside in Houston, it blows and blows but never gets really cold. I expect it is a feon issue, or whatever they use these days. I think I have days left on my one-year basic warranty and plan to put it in the dealer's tonight. Anybody else have this problem? Otherwise, my car has been trouble free.
N
NorthwestGT
177
Pasco, WA
Jun 14, 2006
  • Jun 14, 2006
I haven't had a similar problem with mine after a year, and I have a 'vert. You're right in getting it to the dealer. A/C is covered by the warranty, and they should be able to make it right.
cowtown
228
Victoria, BC Canada
Jun 14, 2006
  • Jun 14, 2006
1 Year basic? I thought these things were 3years min.
G
GT-Tronics
18
  • Jun 15, 2006
Is it a hard top or vert?
I have heard of verts being hard to keep cool.
Also, are you in heavy traffic?
You have to be moving 30+ mph or so for the ac to work well.
Tmack
171
Salt Lake City, UT
Jun 15, 2006
  • Jun 15, 2006
My '02 mustang GT came with a Freon leak from the factory. They added a UV dye to the Freon and found the leak. (A small hole in one of the lines) It was covered under the 3/36,000 warrantee.
torqueIT
122
Phoenix, Arizona
Jun 15, 2006
  • Jun 15, 2006
I live in Phoenix, so that problem was a major issue for me.
Nothing actually wrong with the A/C, just to damn friggin hot here (I believe its 108 degrees out right now!)
Anyway, what I did was go to Home Depot, and went to their plumbing section. You'll find foam pipe insulation there. Grab enough to cover your A/C line and use zip ties to hold it in place about every 3-5 inches (not too tight, or you'll lose the insulation properties of the insulation). When choosing the diameter of the insulation, I just did a cutout with some paper to get the right fit.
I did this last summer and noticed a significant improvement in how quick the A/C cooled down the car. I've had it insulated for over a year now with no issues to speak of.
Spdfreak
276
  • Jun 15, 2006
Best thing to do? Get the hell out of Nevada and Arizona!
cLeAnRaCiNgLdR
98
  • Jun 17, 2006
I just bought a used 05 GT coupe and have noticed this as well...at night it is fine but during the day it just doesnt seem to blow cool...The 2003 GT I traded in use to freeze me out, I would have to let the windows down it got sooooo cold. Im in south FL and its around 93-96 degrees now with 100%humidity... I have a 7 year 100k mile warranty, I guess i better get this checked out.
Infinity
956
Charlestown, IN
Jun 18, 2006
  • Jun 18, 2006
Ditto. I need to get mine checked- my '02 GT would chill your joints to the point of aching, and it still does (friend owns it and I took a ride with her yesterday). The '06 is only cold if I put my hand against the vent.
torqueIT
122
Phoenix, Arizona
Jun 19, 2006
#10
  • Jun 19, 2006
  • #10
Amen buddah!
I'm originally from Denver, and personally, Phoenix is definitely not my cup of tea.
Plan on moving to California sometime next year.
G
GT-Tronics
18
#11
  • Jun 20, 2006
  • #11
Once the inside of the car is cooler than the outside temp, push the recirculate button. That causes the a/c to pull air from inside the car instead of the hotter outside. The a/c can only lower the air temp about 18 degrees per pass, so If its sucking in 108 deg air the best you can hope for is 90 deg at the vent.
Then it should get cooler since the same air is being cooled over and over.
2001 v6 New compressor issue
  • badmech
  • Apr 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Apr 30, 2026
badmech
J
V-6 thermostatically controlled cooling fan - on when cold - new behaviour
  • jacekk
  • Oct 1, 2025
  • 2005 - 2014 Specific V6 Tech
2005 - 2014 Specific V6 Tech Oct 1, 2025
jacekk
J
N
Need stainless carb heat shield
  • newmex999
  • Aug 29, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 13, 2026
Mcmahst
9
1998 V6 - What is this line called?
  • 98_Stanger
  • Aug 10, 2025
SN95 V6 Mustang Tech Aug 10, 2025
nickyb
2005 AC quit working
  • horse sence
  • Jun 26, 2024
2005 - 2009 Specific Tech Jun 29, 2024
horse sence
