  • 1994 - 1995 Specific Tech
Ac Pump Delete ?help
  • Thread starter Thread starter DJTaylor
  • Start date Start date Dec 19, 2005
D
DJTaylor
22
Lake Stevens, Wa
Dec 19, 2005
  • Dec 19, 2005
the ac pump on my 95 gt is going out (loud noise, smell) so i was thinkin i wil jus delete it and get some more power but i am not sure what size belt i need to get.i already know i must pull the pump out from the bottom (from what ive been told) but what belt size do i need please help
CManT1914
3,172
Killeen, Texas
Dec 19, 2005
  • Dec 19, 2005
Best way to determine belt lengths, is to take a piece of string (long) and wrap it around the pulleys in the new configuration. Then just measure how long it is to where the two ends meet, and there ya go.
94Blue302GT
704
Chicago
Dec 19, 2005
  • Dec 19, 2005
lol, and then go and get one just a bit shorter, and then go back and get one a bit longer, and laugh when the people don't know what the numbers are on the belts.
D
DJTaylor
22
Lake Stevens, Wa
Dec 19, 2005
  • Dec 19, 2005
ha thanks makes me feel very eager to get out there freeze my a** off and try
bill302
2,131
alabama,gadsden
Dec 19, 2005
  • Dec 19, 2005
don't throw away you'r reciept you might need it. LOL
D
DJTaylor
22
Lake Stevens, Wa
Dec 19, 2005
  • Dec 19, 2005
thats what i was thinkn thanks, now i know theres going to be a couple hoses i need to bypass but other than that what should i look out for, tips to make it easier on me
T
turbogt
723
Montana
Dec 19, 2005
  • Dec 19, 2005
91" should do it
94opalgt
358
AKRON,OHIO
Dec 20, 2005
  • Dec 20, 2005
when i did away with my a/c and smog i took a ribbon,like you wrap presents with,ran it around the pulleys,measured it and bought that exact length and it fit perfectly.but i had to go to napa to get it cuz az,advance did not carry the size i needed.wait till you pull all those ugly lines and see how much it cleans up the engine bay,i couldnt believe,i wish i had done it sooner.and dont forget about the big cooler for the a/c in front of the radiator,get that out of there also.
ROLLIN5.0
135
Tulsa, OK
Dec 20, 2005
  • Dec 20, 2005
The compressor comes out with four bolts from the driverside. You don't have to do anything on the front of it. There is a bolt holding the lines in the back of the compressor. There will be two connections behind your passenger side headlight which go to the radiator type piece in the front, and there are two connections on the passenger side firewall. Basically, follow the lines, and remove everything that they hook up too. You will need fuel/AC line removal tools. I got the plastic ones at Autozone for like $5. I can't help you with the belt. I did the smog at the same time, and I think my belt is a 71.5" if I remember correctly.
Brandon
Oh, before you start, get the car somewhere rural preferably, and unscrew the two ports on the lines to release any pressure you still have in the system.
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Dec 20, 2005
#10
  • Dec 20, 2005
  • #10
There's probably no single, faster way to have the EPA at your house, if you get caught doing that. Any competent HVAC shop could evacuate the system for you for extremely cheap, and maybe even free if they're feeling generous.
94Blue302GT
704
Chicago
Dec 20, 2005
#11
  • Dec 20, 2005
  • #11
I had to go back and forth to the store 4 times. Once cuz it was too long, so i decided to go two shorter to make sure it was tight on the tensioner, then they gave me the wrong one, then i got one shorter, and then one shorter, and viola! They now know who i am.
D
DJTaylor
22
Lake Stevens, Wa
Dec 21, 2005
#12
  • Dec 21, 2005
  • #12
well thanks it been great help to me
Engine Belt routing with supercharger and smog/ac/ps delete
  • Steve6482
  • Jul 15, 2026
Fox 5.0 Mustang Tech Jul 15, 2026
Steve6482
F
89 GT smog delete belt?
  • fratzke
  • Feb 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 25, 2026
fratzke
F
Fox Help my smog pump :poo: the bed.
  • nickyb
  • Aug 26, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 27, 2025
nickyb
D
Power steering pump bracket with A/C
  • Dczookster
  • Apr 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 2, 2025
rednotch
No spark. 1990 foxbody 5.0 gt
  • Boogi
  • Nov 16, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 16, 2025
Boogi
