  • 1994 - 1995 Specific Tech
AC question?
  • Thread starter Thread starter oosmytoo
  • Start date Start date Aug 20, 2004
O
oosmytoo
530
Portland - Oregon
Aug 20, 2004
  • Aug 20, 2004
my cars AC hasnt worked for two years now and just the other day it decides to start working!? so im thinkin that there is a problem with the switch that moves it from the heater to the AC? does anyone know anything about how that part of the system works? theres a little valve under the hood that has a vacuum line coming from the intake, through the valve, then into the fenderwell. this little valve also has two or three wires in it. mine just hangs there, doesnt look right? i have no idea what its for? but im thinkin this thing could be the problem?
stng94
104
St. Pete, FL
Aug 20, 2004
  • Aug 20, 2004
I dont know if this answers your question but, my car had intermitent ac for a while. turned out it was a faulty ground. check it out. it may be an easy fix.
O
oosmytoo
530
Portland - Oregon
Aug 21, 2004
  • Aug 21, 2004
very well could be? wheres the ground located at?
O
oosmytoo
530
Portland - Oregon
Aug 21, 2004
  • Aug 21, 2004
BUMP!! anyone? now i really got problems, i attempted to try and fix it, but things only have gotten worse! and the only thing i did was pull out the heater/AC controls and look at them? well heres the problem now, i can still turn the heater on but its stuck on defrost. no matter which one i select (max A/c, norm A/c, defrost, vent, floor) it always comes out the defrost vents? can anyone help me? please!
Rootus
Officially Addicted
Feb 8, 2003
6,659
Portland, Oregon
Aug 21, 2004
  • Aug 21, 2004
If it won't switch modes, that's definitely a vacuum leak. Either under the hood, or in the dash somewhere. You should be able to get some assistance from this forum -- I *know* I've heard a couple people talk about broken vacuum lines under the dash causing exactly this symptom.
Dave
O
oosmytoo
530
Portland - Oregon
Aug 21, 2004
  • Aug 21, 2004
Dave
yeah i was thinkin that too, i just dont know which vacuum line too look for, hopefully some of you other guys know what to do! thanks HairyCanary
R
Road_Runna
20+ Year Stangneter
Dec 23, 2002
594
Ogden, UT
Aug 21, 2004
  • Aug 21, 2004
My A/C has started to crap out on my car. A friend of mines is thinking of getting rid of his, and if I can't fix my A/C, im going to do the same. As we where talking, same subject, he said A/C's use up some gasoline, or that A/C's use up more gasoline when turned on. is that true ?
BTW, I think, he's somewhat of a Mustang expert, that **** he's done to his car is insane.
J
Emission problems
  • jls.zmmr
  • Feb 5, 2026
1994 - 1995 Specific Tech Feb 7, 2026
AeroCoupe
O
Sooty/Oily Front Engine & Pulleys
  • ozenator
  • Jun 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 22, 2026
Blackhawkxx
F
Electrical Foxbody wiring harness 2.3 to v8 swap
  • Foxbodyjake
  • Mar 23, 2026
Kleinjj27
K
82 Gen 1 Coyote Swap AC Questions...
  • thinkfaster
  • Aug 14, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 15, 2025
thinkfaster
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
