ac sounds like a ps pump on it's way out ?
johnnyt03gt
5 Year Member
Mar 15, 2008
453
dallas TX
i know another ac question but i really need help
at first i thought my PS pump was going bad i quickly noticed it only happens when ac is turned on and is consistent wiht engine RPM not very loud but loud enuf to get my attention other then the noise it works perfectly blows very cold air ac has never been serviced the car is an
03 has 88k on it i will be happy if it lasts till end of summer im just scared it might "LOCK UP"
and shred my belt and destroy the radiator big problem or easy fix thanks:shrug::dead:
Yea, your ac pump has bearings and a piston to make high pressure only when the pressure switch and the clutch is engaged does that pump and bearings come into use, much like the bearings on your axle, or in your rear carrier when they go bad or get worn they start to make buzzing noises, its not a severe problem, but its a sighn that you will need to replace the compressor. The compressor not going to lock up unless the bearings are toatal gone! Hope this helps:nice:!!!!
Yea, your ac pump has bearings and a piston to make high pressure only when the pressure switch and the clutch is engaged does that pump and bearings come into use, much like the bearings on your axle, or in your rear carrier when they go bad or get worn they start to make buzzing noises, its not a severe problem, but its a sighn that you will need to replace the compressor. The compressor not going to lock up unless the bearings are toatal gone! Hope this helps:nice:!!!![/QUOTE
cool i just needed reassurance i'll replace it spring time befor the next heat wave it's like 107 here in dallas today thanks for the info:hail2::SNSign:
