Engine ACT Code 54 "Sensor circuit open"
k19driver
Redwood City California
Hope this finds you all well.
What I have is a ’93 5.0 stroked to 347. It’s in a 1993 Volvo 940 wagon. Tuned a few years ago by the engine builder at his Sears Point shop.
It passed CA smog checks without too much sweat. The last few weeks I've been occupied doing some engine compartment clean-up. Removing most of the old production line connectors and cleaning up the vacuum hoses. It is still EEC-IV.
After everything was back together, before initial start up I clipped in my Innova EEC-IV Ford code reader.
KOEO: I get a 15 (EEC (PCM) Read Only Memory (ROM) test failed)
then a 54 (Intake Air charge temperature sensor circuit open)
The amazing thing is code 11 shows up after the second group finishes.
Check engine light is ON
The ECU is an X3Z.
I ran a new wire from the ACT sensor (also new) to pin 25. VREF is 5.05 vdc
Temp: 60F Sensor voltage is 4.76 vdc Resistance across sensor terminals is 42.6 K ohms. Both readouts appear to be in range.
Two new Motorcraft O2 sensors installed.
I drove the car yesterday. Seemed to run ok. CK Engine Light on the whole time…
Not sure to how to determine if the ACT sensor data is being seen by the ECU considering the last code seen is a 11
If anyone can think of anything else I might try…
Best regards all...
jeff
  • Sponsors(?)
jrichker
StangNet's favorite TOOL
SN Certified Technician
Mar 10, 2000
27,436
2,869
234
74
Dublin GA
lowendmac.com
Code 51 Engine Coolant Temperature (ECT) sensor signal is/was too high -
[color= blue]Revised 6-Apr-2017 to add diagrams and resistance check for ECT wiring.[/color]
Possible bad ECT sensor or wiring. Possible missing signal ground – black/wire broken or bad connection. With the power off, measure the resistance between the black/white wire and battery ground. You should see less than 1 ohm. Check the same black /white wire on the TPS and MAP sensor. More than 1 ohm there and the wire is probably broken in the harness between the engine and the computer. The 10 pin connectors pass the black/white wire back to the computer, and can cause problems.
The computer Engine Coolant Temperature sensor has absolutely nothing to do with the temperature gauge. They are different animals. The ECT sensor is normally located it the passenger side front of the engine in the water feed tubes for the heater. It has two wires that connect by a weathertight plastic connector.
The water temperature sender for the temp gauge is located in the driver's side lower intake manifold. It has a single wire that connects by a push on connector on the temp sender.
If you have replaced the ECT sensor and are still having ECT like problem symptoms, check the ECT wiring .
See the graphic for the 10 pin connector circuit layout.
Check the resistance of the green wire on the ECT connector to the green wire on pin 7 of the computer connector. You should see less that 1 Ω (ohm)
Use Pin 46 on the computer for ground for both ECT & ACT tests to get most accurate readings.
Pin 7 on the computer - ECT signal in. At 176 degrees F it should be .80 volts
Pin 25 on the computer - ACT signal in. At 50 degrees F it should be 3.5 volts. It is a good number if the ACT is mounted in the inlet airbox. If it is mounted in the lower intake manifold, the voltage readings will be lower because of the heat transfer.
50 degrees F = 3.52 v
68 degrees F = 3.02 v
86 degrees F = 2.62 v
104 degrees F = 2.16 v
122 degrees F = 1.72 v
140 degrees F = 1.35 v
158 degrees F = 1.04 v
176 degrees F = .80 v
194 degrees F = .61
212 degrees F = .47 v
230 degrees F = .36 v
248 degrees F = .28 v
Ohms measures at the computer with the computer disconnected, or at the sensor with the sensor disconnected.
50 degrees F = 58.75 K ohms
68 degrees F = 37.30 K ohms
86 degrees F = 27.27 K ohms
104 degrees F = 16.15 K ohms
122 degrees F = 10.97 K ohms
140 degrees F = 7.60 K ohms
158 degrees F = 5.37 K ohms
176 degrees F = 3.84 K ohms
194 degrees F = 2.80 K ohms
212 degrees F = 2.07 K ohms
230 degrees F = 1.55 K ohms
248 degrees F = 1.18 k ohms
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring http://www.veryuseful.com/mustang/tech/engine/
k19driver
The ACT is located on the lower intake manifold. I may have stumbled across the reason for the 54 code. I removed the ACT sensor, checked the shared signal return to pin 46 resistance. 1.19 ohms. Not good... Clipped it off ACT cannon plug and jumped it to the ECT signal return. Ran Self-Test... no codes!
k19driver
Yes, it was tuned for the MAF. Not sure if the X3Z is the best choice... I became caretaker to the car when the gentleman who originally swapped in the engine maybe 20 years ago passed away in 2007. It was was set up for autocross and track driving. I would like to be more involved in the tuning aspects. The whole process kind of intimidates me. The Tweecer RT interface is in place- but I have yet to use it.
rt
vristang
4,788
42
109
44
Seattle
www.SeattleBlueOvals.com
Not sure I'm following... are you suspecting the ACT plug, or the ACT itself?
If the tune was done properly, then it doesn't matter what factory ecu you start with. Most factory differences were minimal anyway.
k19driver
Thanks for responding- I suspect my talents as a wire splicer...and an inexpensive replacement ACT sensor. Perhaps I did not pay close enough attention to my splices. What started all of this was I removed all of the original production wire harness connectors. Tested and mapped out the pin locations for future reference. But I failed at checking the quality of my work. Lesson learned.
Thread starter Similar threads Forum Replies Date
S EGR Valve Acting Strange *Pulled Codes* Fox 5.0 Mustang Tech 7
W 1997 Mustang GT AC / Radiator fan acting up 1996 - 2004 SN95 Mustang -General/Talk- 0
P Drivetrain 1995 GT Auto Transmission Acting Strange 1994 - 1995 Specific Tech 1
zack2001 2005 Mustang 4.0 Raxiom sequential taillights act up when headlights are turned on 2005 - 2009 Specific Tech 1
J 1990 saleen ACT and ECT sensor location Fox 5.0 Mustang Tech 4
R Engine Carbed Mustang Acting Up Fox 5.0 Mustang Tech 5
P 03 gt auto speedometer acting wonky SN95 4.6L Mustang Tech 2
ChillPhatCat Cold Start Issue... ACT Sensor? '89 LX 2.3L 2.3L (N/A & Turbo) Tech 27
USCGunner Drivetrain overdrive acting weird Fox 5.0 Mustang Tech 2
S 93 5.0 5speed car starts runs strong turn it off and it acts like it has a dead batt The Welcome Wagon 0
B WC T5 not acting right 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 4
H 2005 temperature gauge acting weird 2005 - 2014 Specific V6 Tech 0
H Temperature gauge acting weird The Welcome Wagon 2
Blucifer99 Fox Drilling gt40 lower for egr coolant line and act 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 4
T ACT sensor locations 1994 - 1995 Specific Tech 2
M Ditched The 235/ 18s All Seasons For The Foundry 265 / 20 Summers ... Car Acts Like Its On Ice! 2015+ (S550) Mustang -General/Talk 5
C 2007 Gt, Can't Fill With Gas. Acts Like Its Full. 2005 - 2009 Specific Tech 8
D Please Help Locate Act Sensor Wiring Fox 5.0 Mustang Tech 3
Konrad Kocon Electrical Ac Compressor Clutch Is Acting Weird... SN95 4.6L Mustang Tech 11
P Door Lock/unlock Acts Weird 1996 - 2004 SN95 Mustang -General/Talk- 1
P Engine Explorer Manifold...no Act Hole? Fox 5.0 Mustang Tech 5
A 94 Gt Acts Like It Wants To Shut Down. Fox 5.0 Mustang Tech 4
W Electrical Headlight Nob Is Acting Strang SN95 4.6L Mustang Tech 2
J Fox 1990 Just Bought And Started Acting Up. Need Help. 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 18
D 90 H.o 5.0 No Start Injectors Are Acting Weird. Video Link. Fox 5.0 Mustang Tech 5
FoxMustangLvr H.r.4715 - Rpm Act Of 2016 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 29
Jordan Warta (updated) Car Acting Wierd After Catted X-pipe Install Fox 5.0 Mustang Tech 21
1993cobra5.0 96 Gt 4.6 Auto Acting Crazy Shifting Only In 2 Second? 1996 - 2004 SN95 Mustang -General/Talk- 0
Jordan Warta Car Acting Wierd If Don't Drive It For A Few Days 1994 - 1995 Specific Tech 3
B Jordan Progress Thread Car Dies, Acts Like Its Running Out Of Gas And Misfire In Cylinder #2 1996 - 2004 SN95 Mustang -General/Talk- 0
B.erazo712 Transmission Acting Up??? Fox 5.0 Mustang Tech 2
W Car Is Acting Funny 2010 - 2014 Specific Tech 3
BKM48198 Automatic Trans Acting Up Now. Aod Trans. 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 3
MY 85 GT Iat Or Act Sensor Fox 5.0 Mustang Tech 1
2 Starting Problem. Acts Like Dead Battery But Isn't Fox 5.0 Mustang Tech 2
CanyonCarver515 ’67 Wipers Acting Up, Stop Anywhere On The Windshield Classic Mustang Specific Tech 2
7991LXnSHO Cold Blooded Fi, Acts Like It Needs Choked Fox 5.0 Mustang Tech 22
R Drivetrain 4r70w acting up SN95 4.6L Mustang Tech 26
D Car Acting Like Its Going To Stall? SN95 V6 Mustang Tech 6
Lil-Red Guys I'm new at this, how do you used this thing? where to start? how to post? and act, act? Help. Regional Forums and Event Information 0
turp23 New car acting up already SN95 4.6L Mustang Tech 16
V Gauges acting very strange 2005 - 2014 S-197 Mustang -General/Talk- 8
FoMoCo17 ECT & ACT Sensor voltage Fox 5.0 Mustang Tech 4
linkwpc FS: ACT Clutch NEW in BOX 99-04 COBRA FM3-HDSS Drivetrain Parts 2
Neltech Car dies, acts like its running out of gas Fox 5.0 Mustang Tech 13
ttopstang New alternator, now gauges act up SN95 V6 Mustang Tech 1
I The Old Explorer ACT intake Questions Fox 5.0 Mustang Tech 1
T Heater Fan acting up Classic Mustang Specific Tech 1
K New 2003 cobra acting like ****box SVT Tech Forum 10
5.0Droptop Explorer GT40 intake ACT solutions 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 14
