So do you guys remember my threads last year about the problem I have with my stupid ACT sensor? It's back...right on time with the 70-80* weather
If you don't remember, I have this problem. Whenever my car is in hot weather, it runs like complete ****. Feels like I lose 4 cylinders, hesitation, bog on take off, etc.
Last year I *patched* the problem by replacing my ACT sensor with a resistor, tricking the computer. The weird problem is, simply replacing the ACT didn't do a thing. So as soon as the sluggishness started to come back (today it was really noticable) I drove right over to Radioshack to pick up a 47K OHM resistor. It instantly made a difference in the car, and I didn't even reset the computer.
I'm not even talking a 5hp difference, I'm talking more the difference between having stock gears and throwing 4:10's in
Now from what I've read from the real smart guys, the ACT can barely touch timing, maybe 3-5 degrees at the most. But it CAN affect fuel, injector pulse-width etc.
I also started getting into this: http://www.usnaaaa.com/pingisgone.pdf
But it gets a little over my head.
I'm just wondering if theres anyone out there that can explain this for me. Maybe the ACT wire is open/grounded on the way to the computer.
Thanks guys,
Joe
Thanks guys,
Joe
), getting those couple hundred extra RPM help (if I let it stay in OD). In cooler weather, this is not an issue, EVERYTHING else (including coolant temps) being equal.
Not true at all!
