  • 1994 - 1995 Specific Tech
added AFPR and dyno'd car
  • Thread starter Thread starter mto502
  • Start date Start date Apr 5, 2004
First Prev 2 of 2
Zero Signal
2,633
Tucson, AZ
Apr 6, 2004
#21
  • Apr 6, 2004
  • #21
If the MAF is cut out, how is is the car adjusting the timing and pulsewidth since it has no way of calculating the load? Pretty much all our important tables are based on load and rpm.
mto502
357
Ancaster, Ontario
Apr 6, 2004
#22
  • Apr 6, 2004
  • #22
They told me the o2 sensors take care of that
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Apr 6, 2004
#23
  • Apr 6, 2004
  • #23
mto502 said:
From what I've heard the 80 mm won't fit with my BBK CAI. Will the 77 mm fit and are they as highly/properly calibrated as the 80 ?
The electronics are the same on both mafs.
The 80 will work just fine with a home made cai constructed with a short length of three inch pvc & two plumbing couplers. It can be built for very little $$$.
Later
Grady
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Apr 6, 2004
#24
  • Apr 6, 2004
  • #24
mto502 said:
Yes there is but my engine builder told me today as well as his assistant who used to be a tuner for Ford, that the MAF is cut out during WOT as well
I think it is time for you to find a new engine builder!
As for his assistant who tuned Fords *** Musta been FORD tractors
Later
Grady
Rootus
Officially Addicted
Feb 8, 2003
6,659
Portland, Oregon
Apr 6, 2004
#25
  • Apr 6, 2004
  • #25
He's confused, probably getting mixed up with speed density.
Dave
mto502
357
Ancaster, Ontario
Apr 7, 2004
#26
  • Apr 7, 2004
  • #26
That's great. Thanks for the input folks. My concern now is to decide on what to do. I certainly don't want to open up the car anymore especially after finding out how rich it's running. I'm cleaning my cylinders of oil from all that extra fuel on WOT.
I don't know if I want to get a new MAF or just go with a DFI or Holley Commander stand alone setup in which case I wouldn't need the MAF.
S/CBlack95GT
2,018
Tampa Palms, FL
Apr 7, 2004
#27
  • Apr 7, 2004
  • #27
WOW!!! That is really scary if they use to work for Ford. They must have been the guys sleeping in the corner while the rest of the people did the work. After hearing that you better not trust those guys anymore, they obviously do not know what they are talking about.
Anyway, the 77mm is very precise like the 80mm, however, the 77 is about $100US more. Personally, I would scrap the BBK CAI, b/c I hate BBK , and then get the 80mm MAF and a PowerPipe. The PowerPipe looks much better and it will make more power with the MAF. After that you can redyno the car. You will be spending a lot more money going this route, but I dont think you will be upset later. Remember, you can sell the 75mm MAF and BBK CAI on the internet (ie Ebay) and probably get $100.
mto502
357
Ancaster, Ontario
Apr 7, 2004
#28
  • Apr 7, 2004
  • #28
C & L have an interesting package for the 94/95's as well. How do they compare to the Pro M's? Do you think I'll need that AFPR after I try out a new MAF? You see, here in Ontario, having an open air filter is an emissions violation so I want the filter covered or in the fenderwell like the BBK cold air kit does. The C & L package also has the filter covered up.
I read this about the Anderson Power pipe and this is the 94/95 specific pipe as well :
The entire pipe is held in place by the rubber sleeve on the throttle body. took a long time to twist it and get the right fit, but still bounces around in the fenderwell. Had to custom make a rubber fitting for the fenderwell. No place to put oil breather line. Pipe hits the oil cap and alternator.
I was so disapointed with this product. Way overpriced for what you get. Don't know why they wouldn't make a braket to bolt it to the fenderwell? You'll have to do alot of twisting, readjusting and custom work to get it to fit securely. Would be nice for a drag car, but not a street car.
My engine builder is actually very good at what he does and he is one of the best if not theeee best DFI tuners in the province. He's also a turbo specialist in regards to Mustangs or whatever else you want to put a turbo on. I believe what you say about the MAF at WOT and it's possible that my engine builder made an error in regards to this.
Again, I appreciate your assistance in this matter.
DJHA90
581
Texas
Apr 7, 2004
#29
  • Apr 7, 2004
  • #29
The AFPR ran more pressure than stock -- even with it adjusted all the way down??? Maybe a problem with the AFPR?
Zero Signal
2,633
Tucson, AZ
Apr 7, 2004
#30
  • Apr 7, 2004
  • #30
Well in my experience with mechanics, the good ones I've talked to know exactly what they're doing but not what they're saying. Mechanics aren't communication experts by any means.
mto502
357
Ancaster, Ontario
Apr 7, 2004
#31
  • Apr 7, 2004
  • #31
DJHA - I rehooked up the stock regulator after the AF readings we received with the AFPR and the the AF was just as rich.
Zero Signal - This is true. When he's working I can't even talk to him because he's too busy concentrating on his work...heheee. He's a good guy.
First Prev 2 of 2
Engine Multiple o2 sensor codes, car runs terrible
  • 02newedge
  • Jun 12, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jul 19, 2025
squeak93
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
SURGING IDLE / NO IDLE CHECKLIST FOR 1996–1998 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 7, 2026
2v_johnny
SURGING IDLE / NO IDLE CHECKLIST FOR 1999–2004 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
