Adding 4Ga ground - Where's good?
  • Thread starter Thread starter bloopbloob
  • Start date Start date May 10, 2007
bloopbloob
578
Alberta
May 10, 2007
  • May 10, 2007
i have added my 3G alt, and i want a 4ga ground too. where are good places to add it? I can't get the main ground (behind the intake to the firewall) off. the nut will loosen, but there are other grounds connected to it that spin and start to wrap around the bolt. i can't see what's going on, and i don't want to wreck what exists. so where are other good points to add one? also, should i have a direct ground from the neg. terminal on the battery to the chassis as well? i had one with a big stereo, but i removed it all, along with that ground. opinions? thanks
Busted07
I need my gorilla to be about an inch longer.
Nov 15, 2005
  • May 10, 2007
Look up some JRichker posts on that... i think there is a terminal by the starter solenoid that needs to have a ground by it.. its like an ECM ground or something.
Darkwriter77
Resident Ranting Negative Nancy
5 Year Member
Jul 1, 2005
315
283
134
Apache Junction, AZ
May 10, 2007
  • May 10, 2007
I went with the back-of-intake ground and added a second 4-gauge ground on the front of the block where the A/C used to bolt on, and grounded that directly to the frame. You can never have too many grounds, so when it doubt, just keep adding more - the ricers claim their super-duper grounding kits add 20 horsepower, anyway.
G
Electrical Getting good ground in 1991 Fox Vert for amps - getting popping noise when I turn on the lights?
  • gvanginkel403
  • Apr 11, 2026
Fox 5.0 Mustang Tech Jul 21, 2026
gvanginkel403
G
What's your tow rig?
  • LILCBRA
  • May 31, 2026
  • Other Auto Tech
Other Auto Tech Oct 23, 2026
JH96GT
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
Firewall to engine ground strap?
  • limp
  • Jun 6, 2023
6K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 23, 2023
General karthief
  • dan50
  • Jul 18, 2026
dan50
