adding kicker 12 in. solo baric and amp
SonicGT
187
Ypsilanti, MI.
I have a Kenwood KAC-PS500F 1200 watt amp and a Kicker Solo Baric 12 inch sub in a sealed box, How can i hook up the amp to the stock Mach 460 system? what do i need to get a clean signal and were to hook up the remote on lead from the amp?
i've got the same problem trying to figure out where to hook up the remote. anybody know if there is a remote wire on the stock radio or if the best way is to hook it up to an ignition switched fuse in the fuse box?
Ok here is an additional question.
using the method in the Mustangworld how-to can I run a pair of components for the front and a sub from a 4 channel amp.
I will use the stock rear speakers and stock headunit.
