adjust idle ??
  • Thread starter Thread starter Roland69
  • Start date Start date Jul 22, 2006
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Jul 22, 2006
  • Jul 22, 2006
I was tinkering with my car today I cleaned the throttle blade and sprayed some seafoam in there and let it sit for a bit and ran it....worked good but my idle was a little higher than before so I tried backing out the throttle stop screw to let the blade close a bit more...cant get it to idle under 1100 rpm's
88_GT_5_oh
Sportin' a turbo 5.0 in Canadistan
Jul 4, 2004
WPG/MB/CA
Jul 22, 2006
  • Jul 22, 2006
what i did what, set the throttle screw to te desired idle, the shut the car off and reset the TPS to .98 volts. worked like a charm
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Jul 22, 2006
  • Jul 22, 2006
I was going to play with the TPS but my multimeter was not working (NFG)
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Jul 22, 2006
  • Jul 22, 2006
plus I can't seem to get the desired idle by the screw
Foxfan88
My Grandpa has great wood.
Sep 13, 2004
2,487
Miami, Ok
Jul 22, 2006
  • Jul 22, 2006
unplug your IAC, set your idle at 600 rpms with the screw... shut the car off, plug in the IAC, set your tps voltage to .99 and disconnect battery to reset the computer.
that should do it.
just simply turning the screw hurts more than helps. if you open the blade with the screw, the car thinks its revving slightly, it doesnt know its idling, so you must set the TPS so the car knows its idling rather than a smal smal rev..
i think thats how it work i am not sure, someone correct me if i am wrong...
stang&2Birds
2,091
New England. :-) CT/MA
Jul 22, 2006
  • Jul 22, 2006
The TPS is zeroed out when the engine is started. The adjusting the TPS is mostly a RICER myth. There ARE cases when the TPS has to be ADAPTED. IMHO, anyone that says "ADJUST the TPS" obviously does NOT have an engineering degree and/or they have horrible grammar/English skills.
See:
http://www.veryuseful.com/mustang/tech/engine/Mustang-TPS-FAQ.html
The QUICK summary:
You never have to adjust a Ford TPS unit on a Ford TB (that has the idle set to spec)- NEVER!!
For people that adjust their idle higher than spec to keep their engine running with their setup, or people that use a NON-Ford TPS, then they may have to adapt the TPS unit (by making slots) so that it reads from ~0.6v to ~1.1v at idle.
bill302
2,131
alabama,gadsden
Jul 22, 2006
  • Jul 22, 2006
i did it yesterday just disconnect the iac sensor and set to desired idle with the set screw turn car off and reconnect the iac crank and the idle should stay where you set it with the iac disconnected...
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Jul 22, 2006
  • Jul 22, 2006
cool thanks Bill...do I need to disconnect the batery...I hate setting up my CD player lol
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 23, 2006
  • Jul 23, 2006
The odds are that you have a vacuum leak.
Adjusting the TPS to .99 or higher may increase your idle speed to a higher RPM. In my personal experimenting, there was an increase from 650-750 to 1000 RPM. The increase was not due to a change the mechanical position of the throttle butteryfly.
See "Help me create the Surging Idle Checklist" at http://forums.stangnet.com/showthread.php?t=534062
for help with your idle problems. The first post contains all the updates to the fixes. I continue to update it as more people post fixes or ask questions.
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
2001 SVT Cobra slow return to idle speed
  • phil2001svt
  • Oct 21, 2026
  • SVT Tech Forum
SVT Tech Forum Nov 2, 2026
phil2001svt
Engine Surging idle on start-up
  • keel
  • Aug 11, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
keel
D
Engine Throttle sticky even after cable replacement
  • dqureshi06
  • Aug 16, 2025
Fox 5.0 Mustang Tech Aug 17, 2025
AeroCoupe
2001 v6 New compressor issue
  • badmech
  • Apr 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Apr 30, 2026
badmech
