  • 1994 - 1995 Specific Tech
adjustable fuel pressure regulator
  • Thread starter Thread starter urban96
  • Start date Start date Nov 5, 2005
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Nov 5, 2005
  • Nov 5, 2005
been thinking since im running rich with my 24lb injectors and stock fuel pressure regulator that i should maybe get an AFPR. i already plan on getting it dyno tuned this spring so i dont know if im going to need one for that.
since ECU dosent rear from sensors at WOT is it necessary to have an AFPR to properly tune or do they just change how long the injectors squirt in the tune?
HISSIN50
34
129
Nov 5, 2005
  • Nov 5, 2005
The computer actually does modify the WOT trim on an SN95. On a fox it does NOT. That is why fox guys use the reg's (for WOT performance).
I am not sure that it would help much - the puter might just adapt the pulsewidth back down if you bumped pressure.
But what do I know - Grady and the other wise horsemen will know. Good luck.
legalize420
1,541
South Florida
Nov 5, 2005
  • Nov 5, 2005
if you are running rich, why dont you put the 19's back on. i had to. i was wondering the same thing about neededing one for a tune, i hope to go sometime next week.
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Nov 5, 2005
  • Nov 5, 2005
You know I gotta tell ya'll, the fuel pressure issue is one thing I can say I DON'T know for certain how it effects the tune as I have no hard data from dlogs or anything like that cause I never have owned an afpr.
I have seen many threads where peeps who self tune that I know to be knowledgable have said the pcm will try to negate a change in fuel pressure and THEY have the hard data showing it is so.
So there it is......I don't know the answer...................for sure
Grady
urban96
3,464
Syracuse, NY
Nov 5, 2005
  • Nov 5, 2005
well car is getting put away this week for the winter and i plan to make an appt. as soon as i take it out of storage this spring (already have the chip just need a burn)
Pokageek
2,767
MA, USA
Nov 5, 2005
  • Nov 5, 2005
I have a new un-used BBK I will sell for $40.
9
95cobradude
Banned
Apr 1, 2005
194
long island, ny
Nov 5, 2005
  • Nov 5, 2005
bbk makes the worst regulators, mine went bad and flooded out the intake, ****in car wouldn't even start.
a50sn95
368
Elk Grove, CA
Nov 5, 2005
  • Nov 5, 2005
I just set mine to stock and work on the AFR with my Tweecer.
As long as I have the AFR I need at WOT, why mess with it? Just adds another variable to an already complicated process....
CManT1914
3,172
Killeen, Texas
Nov 6, 2005
  • Nov 6, 2005
Fuel pressure is something you really don't want to change from stock. If you hang around the self-tuning sites, you'll quickly see that peeps always say leave it at stock, even with an adjustable regulator. Why? Too low fuel pressure can lean out the top end of the RPM band, even with it tuned, and ALSO.......... I too (as Grady pointed out) have heard of guys lowering the fuel pressure to lean it out (purposefully) and the PCM eventually compensates and it goes right back to where it was. An afpr is really only a bandaid on a broken bone when it comes to tuning.
C
03 Cobra Low Fuel Pressure
  • CTsnake_03
  • Mar 17, 2026
1996 - 2004 SN95 Mustang -General/Talk- Mar 24, 2026
CTsnake_03
C
C
98 gt fuel pressure issues
  • chasecollier1984
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 2, 2026
chasecollier1984
C
Engine Fuel not pumping
  • Creomod
  • Apr 13, 2026
  • 2 3
2K
Fox 5.0 Mustang Tech Jul 22, 2026
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
Fox Xtremely high fuel consumption
  • PonyGTrider
  • Apr 11, 2026
  • 9 10 11
6K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 9, 2026
PonyGTrider
