  • 1994 - 1995 Specific Tech
adjusting e-brake
  • Thread starter Thread starter 5LiterFever
  • Start date Start date Mar 17, 2004
5LiterFever
134
Alexandria, VA
Mar 17, 2004
  • Mar 17, 2004
hey guys, my e-brake needs to be adjusted. i gotta pull the handle way too far to get it engaged. what's the best way to do this?
AZ95GT
326
Arizona
Mar 17, 2004
  • Mar 17, 2004
I am having the same problem... Help?
Steeda90GT
714
Central Jersey
Mar 17, 2004
  • Mar 17, 2004
me2d2
H
HDS
248
San Jose, CA
Mar 17, 2004
  • Mar 17, 2004
my Ebrake doenst engage anymore. Took it to ford to see if it was a recall
isue. They said it wasn't. But since I got the car a year ago, I'm not sure
if the recall was ever done.
Zero Signal
2,633
Tucson, AZ
Mar 17, 2004
  • Mar 17, 2004
I had the problem and took it to Ford to have the recall done yesterday. I guess they adjusted it as well since now I can only pull it up about 2/3 the way and it engages much better.
I say just take it in and get it done, and hopefully they'll have the courtesy to tighten it up for you.
5LiterFever
134
Alexandria, VA
Mar 17, 2004
  • Mar 17, 2004
i would prefer to just do it myself....i dont really trust anyone else to be working on my car, plus i dont have the time to take it to ford and wait around for them to do it. how can i do it myself?
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Mar 17, 2004
  • Mar 17, 2004
maybe its time for new rear brakes
95snoozer
2,572
RCR
Mar 17, 2004
  • Mar 17, 2004
um there IS a recall on the 95 ebrake assembly
I just havent had the time to get mine fixed
SPUNKIE94
18
alabama
Mar 17, 2004
  • Mar 17, 2004
ok, hold on to yourself cause this gets messy.crawl under the car and find where the e brake cable attaches it's going to be hard to see the driveshafts in the way.there's a bracket spot welded to the body that holds the rear cables at the attachment point if that bracket is bent down kind of pulled away from the body THAT'S THE PROBLEM the bracket has created slack in the cable it's got to be pushed back up. I jacked it back up and welded it.Not for everyone and not so easy either. If the bracket is not the problem then you have to go in the console at the top of the brake handle there's a chrome clip thats attached with a 8mm bolt on the right side of the handle. When removed it releases the gears of the handle so you can adjust the cable. that's the adjustment point.This is where if you can get this to a dealer-machanic-buddy that has done this before it will save you alot of work, I know I did it the hard way.Not that you can't do it but it gets messy. By the way once the cable is tight and the handle only clicks about 3times when you pull it and for some reason you want to remove the console,the console want come out cause the handle has to be almost straight up for the console to clear,remember the little chrome clip cause that's the only place you can release the handle.lots of luck hope this will help
Brakes are engaged while driving
  • stevetbright
  • May 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 31, 2026
stevetbright
Brakes FOX BRAKES ISSUES
  • PonyGTrider
  • Jan 11, 2026
  • 2 3
3K
Fox 5.0 Mustang Tech Jan 31, 2026
Mustang5L5
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
G
Auto City Classics 67-70 Mustang disc brake kit question/s
  • GOvert
  • Jun 30, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 30, 2026
GOvert
G
Hammer shifter problems
  • 387lx
  • Apr 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 11, 2026
General karthief
