Well I installed the OEM lense with the housing yesterday...the ones from 50resto for about $30 bucks each...and transferred the "black" adjusting? plate to the backs of each one and popped them in...and when I turned on the lights my "low" setting is really low and shines right in front of the car and my "high-beam setting" is like my previous low setting...I want to get this fixed for nighttime driving...
Here is the possible problem...I'm assuming it is the top nuts that you turn to make the lights shine upwards but I've got those bolts tightened where they feel like they are about to break (the plastic)...and the bottom ones are on just a bit harder than finger tight because I figured if I tightened those it would be pointing towards the ground more...so in short...my "top" bolts are really tight...is it possible to crack them if I overtighten them...(the way the studs are put into the headlight assembly it seems like it could take some torque but I dont' want to crack new headlights?
The bottom of the headlights are visibly pushed in more than the top part of the headlight...
Also...how is the seal supposed to be positioned when the lights are installed...to get the headlights to go all the way in I had to fold the seal on the edges inwards to wedge it between the turning light and parking light assemblies...is that right?
Do I need to reinstall?...even though I tried a few times with no difference?
The new lenses make it look much better and cleaner...I'll post pics once my alignment issues are helped or corrected
I need to get my valve cover leak fixed first...
