I have the twisted wedge heads with the trick flow stud mount rockers. I am just wandering what the correct way to adjust them is. I have heard that you put the cylinder at the top of the compression stroke with both valves closed take all the play out of the rocker then turn it 1/2 turn more then lock it down. And would using the medium strength threadlocker be a good idea to use??
