Adjusting Valves, please help
  • Thread starter Thread starter streetstang67
  • Start date Start date Aug 7, 2005
1 of 2 Next Last
streetstang67
573
Lexington, SC
Aug 7, 2005
  • Aug 7, 2005
I've had to do this several times in the last month, but every time, I'll have at least a couple noisy rockers. I've been turning the engine over by hand until the valve is completely closed, then tightening until I can't spin the pushrod anymore, followed by another half turn. So, thats what I've been doing, but I still get noise, so what am I doing wrong?
iskwezm
4,159
20
79
Rowland Heights,California
Aug 8, 2005
  • Aug 8, 2005
i was having the same problem.I adjusted them 10-15 times in 3 days,it turned out the cam went flat,hope yours isnt doing the same.What kind of cam and rockers?
rbohm
6,698
550
204
tucson,az
Aug 8, 2005
  • Aug 8, 2005
personally i have never had a ford with hydraulic lifters that had no noise coming from the valve covers, regardless of how often i adjusted the rockers. the closest i came was when i would adjust the rockers with the engine running, and even then in a couple of days the lifters would get dirty and make noise again. i just gave up and live with it. i tell people i have a solid lifter cam in the stang
streetstang67
573
Lexington, SC
Aug 8, 2005
  • Aug 8, 2005
Cam is new, just put it in about a month ago, its an XE256H comp
iskwezm
4,159
20
79
Aug 8, 2005
  • Aug 8, 2005
mine was 2 days old when it went flat.The problem i had was the builder used so much moly lube that it clogged the filter and it went to bypass.This time i put a solid cam and changed the oil after the 20 minute break in and then again a day later and every 100 miles.
Cut your filter open as clean as you can and look for metal from break in and lobe,lifter wear.I wore a lifter down about 1/4 inch,first time ever and I have replaced cams about 5 or 6 times without a problem.
It just what i went through and MIGHT be your problem,but i hope not.
steel1212
1,180
Frankfort, Ky
Aug 8, 2005
  • Aug 8, 2005
I had to adjust mine with engine running as well. Messy, smoky, but done right.
Oh yeah if you have a spare valve cover you can cut the top of so you don't spill oil on your headers/manifolds
thehueypilot
1,084
Medina,Tennessee
Aug 8, 2005
  • Aug 8, 2005
I agree.....adjust them when they are warm/hot and not cold at idle. Adjust them out until they just start to rattle than tighen about 1/4 to 1/2 turn. Take your time and have a good fan handy to clear the smoke away. I find it easier to do one side at a time so I have one valve cover on at a time to limit the mess.
streetstang67
573
Lexington, SC
Aug 9, 2005
  • Aug 9, 2005
Okay, first I adjusted them using the slow, IC/EO or whatever, method. Result, still noisy.
Then I cut open an old valve cover and adjusted with the engine running. There is no constant tick, but occassionally it will sound like something is rattling, mabye a pushrod or the rocker, but its a rattling noise that will last just a second or two and just happens mabye twice a minute. What do I do?
thehueypilot
1,084
Medina,Tennessee
Aug 9, 2005
  • Aug 9, 2005
You could try running heavier weight oil. It might just be a bad lifter.....
iskwezm
4,159
20
79
Aug 9, 2005
#10
  • Aug 9, 2005
  • #10
how was the cam broken in?
The easiest way to do it for me was pull all the plugs and adjust each cylinder at TDC.
steel1212
1,180
Frankfort, Ky
Aug 9, 2005
#11
  • Aug 9, 2005
  • #11
I adjusted with engine running, with a cut valve cover you won't die from smoke lol. Just back each one off until it click and the tighten until it stops and go another half turn. If this doesn't work then something else is wrong.
iskwezm
4,159
20
79
Aug 9, 2005
#12
  • Aug 9, 2005
  • #12
im guessing what everybody told me,losing a lobe on the cam
steel1212
1,180
Frankfort, Ky
Aug 9, 2005
#13
  • Aug 9, 2005
  • #13
Yeah, that would suck.
D
D.Hearne
11,730
south louisiana
Aug 9, 2005
#14
  • Aug 9, 2005
  • #14
If you've still got the stock heads with this cam and springs that match it, your problem is the studs pulling out of the heads. The stock heads on a 67 are pressed into the head and given enough force, they'll pull right back out. You need screw in studs for this type of cam and springs.
streetstang67
573
Lexington, SC
Aug 9, 2005
#15
  • Aug 9, 2005
  • #15
Cam is new and was broken in according to the comp instructions
Heads have screw in studs
And I did adjust with the engine running, so there are no more persistant ticks, just this noisy rattle occasionally
Man this is aggrivating
D
D.Hearne
11,730
south louisiana
Aug 9, 2005
#16
  • Aug 9, 2005
  • #16
Got any other specs or other mods to the engine?
streetstang67
573
Lexington, SC
Aug 9, 2005
#17
  • Aug 9, 2005
  • #17
stock rebuilt 289 with the following upgrades:
slightly ported and polished heads, stock valve sizes
xe256h cam with matching pushrods, rockers, springs, and screw-in studs
4bbl intake, etc...
D
D.Hearne
11,730
south louisiana
Aug 9, 2005
#18
  • Aug 9, 2005
  • #18
Well if it was a wiped lobe, they usually go pretty fast, I had two, one each from Crane and Comp wipe on break-in. Both just a single lobe and both would bend the pushrod when the rocker came loose. Sure it's rocker noise and not an occasional header leak? What rockers are on there?
65up2d8
281
Memphis, TN
Aug 10, 2005
#19
  • Aug 10, 2005
  • #19
If I remember your earlier posts correctly, you installed the cam without screw-in studs and the like and had problems that necessitated going to screw-in studs, etc. Is that correct, or do I have you confused with someone else? If my memory serves me well, you may have wiped out a lobe on the cam prior to doing the current mods. I certainly hope that's not the case, but it sounds quite likely at this point, unfortunately.
streetstang67
573
Lexington, SC
Aug 10, 2005
#20
  • Aug 10, 2005
  • #20
you are correct, this cam swap has been a lot of agrivation, but its slowly coming together. First I installed the cam, broke it in, then took it to a shop for A/C issues. I also told the mechanic to adjust the valves while the car was there. He told me the studs were pulling out. When I got the car back, I took the heads off and the machine shop said they hadn't moved, but I had them install screw-in studs anyway. Now, this.... :damnit:
1 of 2 Next Last
getting 90 PSI at fuel rail - help
  • skidad
  • Oct 17, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
skidad
G
Engine Pushrod Length Question
  • germain101
  • Sep 22, 2025
Fox 5.0 Mustang Tech Sep 25, 2025
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
