ADJUSTMENT QUESTIONS
Press this key one time.
The associated light should extinguish. In this image, it's indicated in [green]. Some keyboards have a different arrangement. :jester:
In the meantime, I'll move this thread over to the Fox section.
Good Luck :nice:
  • Haha
Reactions: Boostedpimp
With the limited info I would say set the fuel pressure at 7lbs and the timing at 12°, that should get you started, you can bump up the timing to what the engine likes as you drive it. You will also find if the fuel pressure is ok, if it runs out at the top end you can bump that up a couple pounds at a time.
