Heres what I can think of, post your opinions and I'll add them to the list. Maybe if we're lucky we can make the FAQ! We can use this as a reference so people can choose what block to start their project with.
PUSHROD
STOCK 302
Pros
Cons
STOCK 351W
Pros
FRPP Sportsman
Pros
FRPP A4
Pros
Pros
Cons
FRPP R-302
Pros
Cons
I dont know very much about the Dart/World blocks so some one please let me know what models they have, I think its just sportsman and other one.
PUSHROD
STOCK 302
Pros
- Cheap/Inexpensive( Anywhere for free to $150 average)
- Mexican blocks are strongest of the 302 blocks which can be indentified by "Heche en Mexico" in lifter valley and weird bumps on front of engine
- Comes as OEM on most Mustangs
- Somewhat lightweight ~ 135 pounds
- Many different options (ie. 306/331/347)
Cons
- ~550 RWHP MAX in most cases
STOCK 351W
Pros
- No replacement for displacement
- Many different options (ie. 358/393/418
- Somewhat cheap/inexpensive ($50-$150 average for bare block)
- C=60's, D=70's, etc.....ie C9=1969( Apparently the stongest of the 351 blocks due to thicker webbings and higher nickel content
- Expect to gain 100 #'s from swapping from 302 to 351
- Need new distributer, lower intake manifold, wider fuel rails(or modify stock), new flywheel/balancer, exhaust due to taller deckheight
- ~700hp RWHP MAX- Someone correct me if im wrong this is just what I understood
FRPP Sportsman
Pros
- Marginally stronger then a OEM 302 (Rated at 450 hp, should hande around 600)
- 145 pounds
- Fairly expensive( I think around $1200)
- Most will agree that cost of this block does not equal benefit
FRPP A4
Pros
- 4 bolt mains
- Very strong ( I believe upwards of 1000 HP)
- Still can be found with a stock bore
- Not too expensive if found used
- Not available new anymore
- Weight gain with this block
Pros
- Available new
- Higher max bore then R block
- Very strong (actual numbers unknown as it is a fairly new block)
Cons
- 2 piece rear main seal
- Splayed 4-bolt main caps on 2, 3, and 4 caps
- Cast Mains
- $1732 price tag
FRPP R-302
Pros
- One piece rear main seal
- Nodular mains (Stronger then Cast)
- True 4 bolt mains
- Very strong ( upwards around 1600 hp-correct if wrong)
Cons
- Weight gain (160 #'s vs 135 #'s stock)
