You will need to figure out how to get the rear brake lines to work. MM makes a kit (MMBAK-21) to adapt the IRS brake lines to earlier cars. Double-check that it will work with your SVO.
I have purchased 3 "low mileage" IRS assemblies over the years, every one needed the differential rebuilt. I would recommend checking the diff before you install it in the car.
If you are planning to use the IRS for performance driving, I highly recommend upgrading to Full Tilt Boogie Racing bushings (and their other IRS improvements). The OEM IRS bushings are not very good. The Cross-Axis Joint Boots also tend to go; it's worth replacing those, too.
I opted to go with poly UCA and LCA bushings on my IRS-swapped 2004 V6 and wheel hop hasn't been an issue (220 hp). There is more wheel hop with the poly bushings on my IRS-swapped 2000 GT (300 hp, more tq than my V6). If you are planning to add a ton of power, you might want to go with the FTBR Delrin UCA/LCA bushings.
Some other issues you will encounter:
1. You will need to modify the frame where the quad shocks mount to get the Rear IRS Brackets to mount correctly.
2. You will need to spread the lower torque boxes to get the IRS subframe to fit properly (the FTBR Bushing Removal Tool helps with this process).
3. Make sure you remove the pinion snubber on your chassis.
4. Install the sway bar and the UCAs before installing the IRS subframe into place.
5. You cannot jack the car up from any part of the IRS assembly. Many people/shops don't know this and they end up damaging the IRS.
6. It is possible that you will have to shorten your driveshaft, but I'm not 100% sure about the SVO driveshaft length. I had to take 1" out of the driveshafts on both my New Edge cars.
I have videos on my YouTube channel about the parts I used and the issues I encountered on my 2004 V6, most of which will pertain to any IRS-swap. I can post them in this thread if you'd like.
