Advice on a fuel pump for 1966 w/351W
rks34th
I would appreciate some advice on changing a fuel pump on a 1966 with a 351 windsor. The current pump is a holley which seems to have ruptured since it spits gas out when the car is turned ON though the top which appears to be a valve opening. I haven't changed a pump before so the advice I would appreciate is the proper steps to take and if there are other services I should perform while I replace the pump.
It's pretty easy, disconnect the fuel lines and undo two bolts. Notice when you remove it, it doesn't want to remain parallel to the block, when you put the new one on you'll push it against the block to start the bolts.
