AFR 165 intake port dimensions, anybody?
Jason 302
685
71
68
Newark, Ohio
Does anybody know the dimensions of the intake port of AFR 165 heads? My dad wants to port match my stock heads and Edelbrock intake to a Fel-Pro 1250 gasket (2.00 x 1.20) but I don't want my intake manifold port to be bigger than the AFR's when I get them in a few years. And I definatley don't want to touch the ports in those AFR's to make them match. Thanks.
Jason
Here you go.... www.airflowresearch.com
Basic Package Components
100% CNC Ported Combustion Chambers
100% CNC Ported Exhaust Ports
100% CNC Ported Intake Ports
Competition 3-angle Valve Job
Intake Valve, 1.900” stud mount, AFR #7200
Exhaust Valve, 1.600” stud mount 58cc, AFR #7219
Exhaust Valve, 1.600” stud mount 61cc, AFR #7220
Intake Valve, 1.900 Pedestal, AFR #7201
Exhaust Valve, 1.600 Pedestal, AFR #7226
1.450” OD Hydraulic Dual Valve Spring with dampner, 120 lbs. on seat, .550” maximum lift (upgrades available), AFR #8020
10º Chrome Moly Retainers, AFR #8510
10º Valve Locks, AFR #9005
3/8” Rocker Studs, AFR #6410
5/16” Guide Plates, AFR #6107
Valve Seals, AFR #6611
Hardened Shims, AFR #6326
Intake Valve Seats, AFR #9059
Exhaust Valve Seats, AFR #9069
Bronze Valve Guides, AFR #9049
Special orders available upon request
All Accessory Holes are Predrilled & Tapped!
Specifications, Features, and Supporting Components
Head Torque 65-70 Ft. Lbs. with 7/16” stud
Rocker Stud Torque 55-60 Ft. Lbs.
Rocker Pedestal Torque 25-30 Ft. Lbs.
Intake Port Gasket, 1.200”x2.000” Fel Pro #1250, AFR #6828
Exhaust Port Gasket Fel Pro #1415, AFR #6837
Head Gasket 1962-82, Fel Pro #1011-1, AFR #6808
1983-93Fel Pro #1011-2, AFR #6809
Head Bolts & Studs Standard ARP, AFR #6323 & #6322
Head Bolt Washers Manley, AFR #6320
Stud Girdle Standard
Suggested Manifold RPM Performer, Performer
Spark Plug Starting Range Autolite 3924
Combustion Chambers 58cc or 61cc
Spring Pocket can be cut to 1.625, no deeper.
Valve Spacing Standard
Rocker Arms Standard, will not accept rail rocker arms
Valve Angle Standard
Angle Mill (10cc Maximum Mill) .008” per cc
Flat Mill (4cc Maximum Mill) .006” per cc
Do not port to the gasket. The AFR heads have the same width and height as the 1250 gasket but the corners of the AFR heads have 3/8" radius corners and the 1250 has much smaller ones. Wait till you have the heads and make a template off the head to put on the intake for scribing.
Tom, glad you chipped in. I taped some posterboard to my intake and then cut out the ports. Then I took some elmer's and bolted it to my heads. Worked out nice, big lip at the bottom side of the port on the heads so I took that off along with some around the sides. The ports where close to the same size but in different positions. So there are no lips now but there is a dropoff on the roof and some of the sides. Should I do the same to my intake or not worry about it?
Port the intake to the heads, not vice-versa. Yes, the AFR head has a slight bias to one side of a stock centered runner. Make the template of the head, not the intake and use that on the intake.
