AFR 185's Spring Upgrade
When I bought my 185's I went ahead and got the spring upgrade, they use .100 longer valves.
Is there going to be an issue with valvetrain geometry, will I need special rockers or with the FMS 1.6 RR's work fine?
I will check pushrod length, only thing I can think I will need is a longer pushrod but the studs and valves are not parallel to each other so in essense the valve tip will be closer to the stud. Is there an issue here or will regular rockers work?
