  • 1994 - 1995 Specific Tech
AFR 185s
  • Thread starter Thread starter Therian
  • Start date Start date Jun 13, 2006
  • 3
1 of 3 Next Last
Therian
The Highlander
Waterloo, Ontario
Jun 13, 2006
  • Jun 13, 2006
Looking for some opinions
I think I want to go with these heads for several reasons:
1. They are the biggest heads I can find that are emissions legal
2. They should support a decent amount of power, and yet shouldn't be too big for my current engine
3. They seem to satisfy my goals for long term performance
Now I have a couple questions (and here's where the opinions come in)
1. Is there another head that is e-legal and bigger (or will support more power)
2. I have heard of piston to valve clearance issues. I have also heard that you either need to notch your pistons or go aftermarket. Is there a lightweight, forged aftermarket piston that will not require any boring (I don't want to go .30 over) or balancing (I know I'm asking too much..ha)
3. What is the absoulte best valve job I can get on this head (I want it to be comfortable revving).
Thanks guys
Grn92LX
Fidanza Man!
6,819
64
129
New York
Jun 13, 2006
  • Jun 13, 2006
205cc TW heads are bigger and have emission ports.
How do you know that your engine doesn't need an overbore? It ain't that simple.
Therian
The Highlander
Waterloo, Ontario
Jun 13, 2006
  • Jun 13, 2006
I didn't say it didn't need one. I said I didn't want to. cause I wanted to rev the block a bit (not too much) and I didn't want to sacrifice any of its integrity. though I'm sure .30 over wouldn't make that much difference
G
Green 94 5.0
2,601
12
79
Ft. Lauderdale, FL
Jun 13, 2006
  • Jun 13, 2006
Thanks guys
what exactly are your long term plans. afr 185's seem a bit big for a stock compression 302 unless you are going with a power adder.
Killercanary
The car that set the bar.
Altoona, PA
Jun 14, 2006
  • Jun 14, 2006
SRP makes a standard bore forged piston. We run them in my dad's '91GT. He had bought a new stock block from summitt when they had them and didn't want to bore it, the SPR's were one of the very few standard bore pistons we could find. It ABSOLUTELY will need to be balanced though as they were a lot lighter than the stockers and they really threw the balance of the assembly off.
As for a valvetrain that can be rev'd, http://www.flowtechinduction.com offers some really nice spring upgrade packages that can accomodate your needs.
fiveoho
1,958
TN
Jun 14, 2006
  • Jun 14, 2006
I have a brand new set of AFR 185s sitting in the floor for my soon-to-be combo and now im getting told that these heads WILL not work with a na 306setup. i have researched this to death before i bought these and i knew they were a little big for that setup, but not terrible big. there were several guys on here that said they were a little big but not bad. the main reason im concerned is because the guy that told me this has 30 years experience building ford based engines. i dont know how much, if any, experience he has with AFR stuff either.
i guess this sorta goes along with what Therians original post was: will 185s not work with a na 306?
Killercanary
Altoona, PA
Jun 14, 2006
  • Jun 14, 2006
fiveoho- they will absolutely work, the only reason I could see them being an issue is if you have some .030" over pistons that have the stock sized valve reliefs in them, otherwise bolt them on and go!
fiveoho
1,958
TN
Jun 14, 2006
  • Jun 14, 2006
PHEW!!!
ive read alot of your posts and from what i can tell, you seem to know your stuff. im a little concerned about my pistons...i dont have any yet. overlook my ignorance here: is there any pistons i can buy with enough relief already in them so i wont have to do any additional grinding? if so, please let me know
so my car shouldnt be a dog with the 185s ?
G
Green 94 5.0
2,601
12
79
Ft. Lauderdale, FL
Jun 14, 2006
  • Jun 14, 2006
with the proper valve reliefs the afr 185's will certainly work. what i was saying with my post was that a smaller head such as the afr 165 is much better suited for a stock compression n/a 302. you will not see the full potential of the 185's with that setup. if you do want to use the 185's i woiuld recommend a higher compression piston with the 58cc 185's. the added compression from the pistons and the smaller chamber 185's should compensate for the lower displacement somewhat. as far as an off the shelf piston goes, im certain you will be able to find one. i have the probe srs pistons in mine. they have plenty of piston choices and may be worth making a call to. keep us updated on how it goes.
fiveoho
1,958
TN
Jun 14, 2006
#10
  • Jun 14, 2006
  • #10
preciate it man. i will
i think i will check with SRS also
Methodical
1,192
11
59
Clinton, MD
Jun 14, 2006
#11
  • Jun 14, 2006
  • #11
Thanks guys
Well, I can tell you this for a fact. I sent an email to FTI with my planned combo, which is in my sig, and he adamantly stated that I should not use the 185s unless there was forced induction. He said something about the velocity would not work well on a NA 306 - 347 yeah but not 306 - something about low end torque (can't remember it all right now). He said the 165s were best suited for my NA 306 because of the velocity. I think I can pull up his responses to my emails. Now, maybe he's done more work and changed his mind but that is what I was told by FTI.
As far as valves, I'd suggest you just tell AFR what you want and they will build to suit. No need to buy heads and then ship to someone to do other work. Let only one person touch those heads that way if something goes wrong you won't get the finger pointing game. Again, just let AFR do the work for - hell they are the ones who make them. That is what I did - told them what I wanted and they built to suit. Again, no need to have others do the work. And, the prices are comparable.
Hell, check out what heads KillerCanary's using and look at the 1/4 mile time.
Killercanary
Altoona, PA
Jun 14, 2006
#12
  • Jun 14, 2006
  • #12
I agree on selecting the 165's over the 185's on a 302, but on a 306 where I could get away with the 185's it'd be a harder choice but it would completely depend on what my intent was for THAT combo. If was going to be mild combo like the one I run now, I'd stick with a 165. If I was going to run something wilder I may go with the 185, it all depends on the combo.
Ed sells the heads with the upgrades already installed, so there is no need to send the heads to him to have stuff replaced. As was also mentioned, you can call up AFR and they can help as well. I've delt with Jason there and he is a top notch guy that can help you with your head selection choices. He's very knowledgable and a cool guy to talk to, he too has helped me a lot with my combos.
This is correct!
fiveoho- Will you car be a dog with the 185's... not if you set the rest of the combo up right to take advantage of the head. It may involve more compression, more gearing, etc but if setup right it'll be a beast.
Most aftermarket pistons are cut to accept a 2.02" valve, but its best to never assume that they will just work because they are aftermarket. Call around and ask the piston manufcaturers what diameter valve the piston is cut to accept.
I run the AFR 165's on the setup in my sig. My new setup will be topped off with 185's.
fiveoho
1,958
TN
Jun 14, 2006
#13
  • Jun 14, 2006
  • #13
i would be interested in the email response FTI gave you if its not too much trouble to get.
as far as the valves go; when i ordered my heads i had AFR do the spring and valve upgrade. so im already on top of that. they built the heads, they done the upgrades.
fiveoho
1,958
TN
Jun 14, 2006
#14
  • Jun 14, 2006
  • #14
This is correct!
i think i may give jason a ring at AFR. as for -making my combo work with those heads-........i know my intakes a little smallish. as far as the cam, i have 'bigger' heads so i picked a 'bigger' cam
( TFS 2 : i know i know....shelf cam ) .
im also going with a 3.90 gear to compensate for the expected softness on the bottem end.
Do i just need to do a 331 instead of a 306? for financial purposes, i want to still do a 306.
mootang
907
texas
Jun 14, 2006
#15
  • Jun 14, 2006
  • #15
if you haven't built your engine yet then i would certainly go with a 347. it shouldn't be that much more expensive than a 306 and it will be well worth it! especially with those heads. and if you can get a custom cam from FTI! if you run this setup with a decent compression ratio you can make some really awsome #'s.
check out this link......
http://www.fordmuscle.com/archives/2005/02/YellowFever/index.php
Methodical
1,192
11
59
Clinton, MD
Jun 14, 2006
#16
  • Jun 14, 2006
  • #16
I will search for them. They are archived.
fiveoho
1,958
TN
Jun 14, 2006
#17
  • Jun 14, 2006
  • #17
its not that i dont want to do a 331 / 347. just the $$ . i put a pencil and paper to it once. to build a 306 and build a 331, its about $800 difference- give or take.
wonder if i could come out any better with maybe just buying a shortblock from DSS or somewhere?
fiveoho
1,958
TN
Jun 14, 2006
#18
  • Jun 14, 2006
  • #18
thanks man
mootang
907
texas
Jun 14, 2006
#19
  • Jun 14, 2006
  • #19
well if your not in a huge hurry it would definatly be worth the wait to save a few extra dollars and go that route!
Methodical
1,192
11
59
Clinton, MD
Jun 14, 2006
#20
  • Jun 14, 2006
  • #20
fiveoho said:
thanks man
Searching........
  • 3
1 of 3 Next Last
My next project , a 428 build!
  • horse sence
  • Jul 29, 2026
  • 9 10 11
4K
Classic Mustang Specific Tech Yesterday at 8:37 PM
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
G
4.6L rods and piston into a 5.4L
  • Green mustang
  • Jun 11, 2025
2005 - 2014 S-197 Mustang -General/Talk- Jun 11, 2025
Green mustang
G
W
I have some 4.6 questions.
  • whiskerz
  • Nov 14, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Nov 25, 2025
squeak93
