Darkhorse845
Banned
That's a great set up!allcarfan said:You will want an RPM intake and an xe266h cam.
Not to be picky, but torque is not power, it is torque. Mathematically, they are two entirely different things.ratio411 said:You have focused on a lot of torque producing parts, but you are forgetting to take into account the torque/hp relationship.
Torque is the power your engine makes.
HP is how fast it can produce that torque.
Max Power said:I never advocate building motors piecemeal. Usually costs you more in the long run.
I'd have to agree with that thought completely.
Not to be picky, but you have it backwards.reenmachine said:...Horsepower makes you go fast, torque gets you to that speed quickly...
Max Power said:I never advocate building motors piecemeal. Usually costs you more in the long run. You don't want advice so I'm not gonna offer any.
Ratio, the line between single planes and dual planes is getting very blurry. I see a lot of dyno tests and the best dual planes make power up top just like milder singles, and milders singles aren't giving up much down low to the more radical dual planes. Different engines with different cams respond differently, of course, but it's a horse apiece at this point. I know your a big advocate of milder singles planes, but good dual planes are right there.
No.WantaGT said:what would those numbers be to the wheels through a c4?
Dave, I'm running Tri-Y's on the 331 stroker in my Ranger, there's NO loss of power with them. This 3800 lb, aerodynamics of a brick, 89 Ranger runs mid 13's with them, thru the mufflers, on street tires. My Canfields are probably the equivalent of the AFR 165's, same sized valves (1.94/1.60) They flow around 270 with the .587 lift cam I'm running on the intake and around 200 on the exhaust side. With the same heads on a 5.0 short block and a B303 cam (1.7 rockers), the motor would pull to 7500 with them. On the 331, all I push it to is 6500, no need to go higher. Plus the 331 has way more bottom end (starts to pull at 1500 instead of the 5.0's 3000) than the 5.0 they were on had. After running the 331, I'd much rather have the bottom end than stressing the motor up at the top end of the rpm range. He'd never miss the 185's on a 302 short block with the 165's and a good dual plane intake. Sure the 185's will make more power, but it'll be at the upper end of the rpm range,ratio411 said:I would also like to note that there is no way I know of to model Tri Ys, so all have been 1.5" primary LTs.
Not to be picky....well, OK, now I gotta be picky. Sorry to get all "engineer" on you:ratio411 said:Not to be picky, but you have it backwards.
Torque is a measure of power.
Horsepower is a measure of time.
Torque is the power attained, and HP is how fast it can be made.
OK, lecture aside, you are basically right.ratio411 said:If torque won races, a diesel couldn't be beat in the quarter.
I have 500 ftlbs of torque in my Powerstroke, but only 210 hp because it is slow and steady torque.
That is what I am getting at... you build everything for torque and you won't get your et.
There must be a balance.
Dave
It's just a matter of terminology, and I'm an anal-retentive engineer so terminology is sacred to me. Of course "performance" is a combination of horsepower and torque, and there must be a balance, as your example demonstrates. You wouldn't want to try to tow your car trailer with a Peon SRT-4 even though it has the same horsepower as your Powerstroke either.WantaGT said:hey sorry if i offended you, i didn't mean too. what i meant to say is i'll eventually get the rpm and bigger cam but I have the heads off any ways and that's all I can afford right now. I WILL put the better parts on later but I just can't right now. sorry if that came out offensive. Alright after looking around i've pretty much decided i need alot of suggestions. I like the brodix, afr, tf, ptl and rpm heads. a plus i see with iron PTL's is that I could afford to upgrade my intake while i'm at it. now i am asking for advice and my bad about earlier maxpower
I have no experience with Pro Topline, so I can't comment. Brodix are a respected name, but I personally haven't used them. I would be comfortable buying them.WantaGT said:btw how much did you pay for your rpm's. i think i've found the rpms for $999 brand new...
