AFS wheels are on the way. What tires to run?
MYSTICSVT
349
Meridian, Idaho
Did a search. Wasn't very conclusive.
Here's my mods:
AFS Cobra R wheels - 17x8(4.95" BS) front , 17x9(5.95" BS) rear
FMS "C" springs
BOI upper and lower arms with no quad shocks
What is the largest tire combo I can get away with no rubbing issues?
Get 245/45/17's up front and 275/40/17's out back. They will fit the wheels perfectly and both be the same overall diameter as stock. Don't let anyone tell you different, I work in a tire store and know how those tires fit on those size wheels.....if you want it to look perfect and not have your speedo out, that's definitly what I recommend.
EDIT: You might have very slight rubbing issues in the front. If you don't want any rubbing at all, then 235/45/17 for the front. It'll make it slightly narrower and slightly shorter.
