Hey guys, I just finished my TFS swap and the car is running very rich, it will burn a tank of gas in 1 day of normal driving. The car also does not like to idle when you first start it up, it will hunt around for the idle with about 300 rpm surging and Ill have to give it a little gas to stay running, this goes for about 20-30 sec.
Also when coming up to traffic lights and stuff, when I come off the gas and out of gear to brake, the car will stall out if i dont give it a little throttle. It will do this no matter how warm/cold it is.
The car also seems to be running a little too cold, the needle stays below the L in Normal on the temp gauge and sometimes even close to the 130 mark. I swaped out the stock thermo for a 180 degree, new standard volume water pump, and I also have a 2 core FRPP radiator. May this be causing it to run rich?
Lastly, when I rev the motor from idle it will choke once really quick sometimes then rev.
Timing is at 14*, fuel pressure @ 40psi vac off/30psi on
A/C + Smog deleted, no check engine light, 100k miles
Im running the TFS kit with stock injectors/MAF/throttle body.
Thanks for the help.
)...I say just get a new one so there's no hassle in cleaning it. It's pretty old lookin'
