After the pi swap
Bridges77
Michigan
I have a 98 Gt with stock npi block. I have pi cams and intake. Also c/a, stock headers, off road h-pipe, catback and 4:11 rear end gears. What should I do next for more power? With the list above it pulls really nice but now it’s slow to me, any suggestions? A power adder is down the road.
thanks
Well, it depends on your long term goals. If you were sticking with N/A, the PI heads would give you a big bump in HP, but it would also bunp your CR up to around 10.5:1 meaning you now need 91+ octane and might put a dent in your forced induction plans.
full PI swap, (heads, cam, intake) plus exhaust, plenum and TB would get you in the 290-310HP crank range. Aftermarket cams in those heads might get you a little bit more.
