Hey gang!
Seven years ago, you all helped me write a series of articles for a magazine that covered classic Mustang brake upgrades at that time. And, gave out credits to all that helped here.
Many editors and magazines since, it is time to update that story, as I am sure there is new and improved systems available now.
So, here's the parameters:
Can be Ford or Aftermarket
MUST be bolt-in, NO welding or custom machining
MUST be able to do with hand tools
MUST be compatible with available wheels, 17" max dia
Looking for front systems, including drums upgrades
All rear systems Must use either 8" or 9" axle, NO Fox swap.
So, what is on your pony, how do you like it, how was the installation, what options are there with your system? Post a pic or two also, and let's see what can be used.
As usual, many thanks in advance for your help and input.
As for my cobra, I'm still beating it to death! Now pretty much a race car. and, would you believe Deanna is a senior at Penn State?
my best to all of you,
Dan
Dan
16's are easy (cheap), so I'm thinking the GT rotors would work out for me.
