Aftermarket Headlight blowing fuse
It's probably you car's way of telling you not to install those hideous headlights on it :p
Was swapping out the headlights the only thing you changed? It's wierd that the turn signals don't work as well.
Yes, that's the only thing that was changed. As soon as I put the stock ones back on, fuse didn't blow, everything was working. Even when I put the left side new headlight, the right one malfunctions as well. I'm thinking a relay will fix issue but could be a bad aftermarket set also. I've done many headlight upgrades and there's always an issue, it's never as easy as it looks, but eventually I figure it out. My brother isn't as patient so trying to see if other mustang owners would know what it could be
