  • 1994 - 1995 Specific Tech
aftermarket hood alignment
  • Thread starter Thread starter HuebyStang94
  • Start date Start date Jul 10, 2006
HuebyStang94
133
STL
Jul 10, 2006
  • Jul 10, 2006
Typically on the SN95 cars, have people had to adjust the hood bracket where it mounts on to the BODY for alignment (not the mounting bracket to the hood)???
Also, have many modifications to the stock hood latch been required, or slight movement up/down??? I'm still working on getting mine to close all the way... It's like it goes in half way....
Just curious of any tips, etc. I am installing a Cobra RR hood on my 94. It's cockeyed a little bit in the front, and it seems there is a 1" clearance problem with it closing all the way.
D
Danman765432
471
Nutley, NJ
Jul 10, 2006
  • Jul 10, 2006
The main way i got my hood to finally shut is messing around with the rubber mounts that the hood hits and rest on when closing. They are located on each side of the car in the front and you can twist them so they sit higher or lower. I had to go through a ton of **** when putting mine on since i got in an accident and my frame was slightly bent and the hood latch pipe thing was bent all over the place and the hood latch was slightly bent. Wound up getting it all figured out after a few hours.
If you still need help on what i am talking about ill take pictures for you
Still need an Alignment?
  • from6to8
  • Jun 1, 2025
1994 - 1995 Specific Tech Jun 2, 2025
AeroCoupe
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 7, 2026
2v_johnny
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
Eight inches is enough for me...
  • 351MooseStang
  • Nov 27, 2025
1974 - 1978 Mustang II Talk & Tech Mar 2, 2026
Bullitt347
A definitive answer to the question of how much height Energy Suspension isolators add
  • 2000xp8
  • May 20, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 20, 2025
2000xp8
