Aftermarket MAF
Joelfan
Hey all..was wondering if you can help me out. Got an 89 5.0 lx...recently had starting problems and extreme lack of power. Finally noticed the gunk buildup on the MAF sensor wire. After cleaning, ran like a champ! I mean like brand new! Still had some erratic starting and idle problems at times, so I switched out the sensor at Autozone for an aftermarket. Now car starts fine, idles great, but didn't have the power it had after I cleaned the wire. And now, a few months later, I can't pass emissons for HC at idle. I pass no problem under load, but fail at idle. I noticed at idle it seems like the car is missing a bit. Replaced all plus, wires,cap rotor. Even with my old crappy MAF with all the gunk I used to pass easily. Anybody have problems like this with an aftermarket MAF? or could it be just a clogged injector? Thanks for any suggestions!
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
attachment.php
index.php
index.php
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see http://www.midwayautosupply.com/pc-7208-90-equus-digital-ford-code-reader-3145.aspx – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
Right now you are assuming that the cause of ALL your problems is the MAF.
This may or may not be the case.
As JRichker outlined, you need to pull your codes.
When you say aftermarket MAF, do you mean that you purchased a calibrated MAF tube and sensor? If so, what brand?
OR
Do you mean that you purchased a direct replacement sensor for the stock MAF meter?
jason
I'll check the codes and see what comes up. I purchased a replacement stock unit MAF (with sensor attached) from autozone. Only reason why I think it's faulty is because immediatley after swapping it out, It didn't accelerate as well.
