The stock drivers' side valve cover is full enclosed.
The stock passenger side valve cover has the filler tube, cap, and a tube line which runs to the Throttle body.
My new 347 crate engine came with oversized valve covers to accomodate the larger rocker arm assemblies. Each valve cover has an opening. The builder included a push-on breather on one side, and an oil fill cap on the other. The builder dynoed this engine using a carburetor, but I'll be using fuel-injection.
What changes, if any, should I make. I suppose I'm most concerned about the tube line which goes from the stock valve cover to the throttle body.
Any help would be greatly appreciated.
-D
-D
i always thought that the crankcase vapors were pulled back through the line from the filler tube into tb.... i know the pcv valve is in the manifold, but i'm not sure what you mean here.....
