Aftermarket wheel studs?
DLo
57
I broke 2 wheel studs recently in the front, one on each side. I think it was a combination of wheel spacers and overtightening on the lugs, so I'd like to pick up some aftermarket ones that are stronger. I'm not running too thick of a spacer, they're less than a half inch thick. Only reason I'm using the spacers is because of minor rubbing on the front when I'm at full lock. Any suggestions? TIA.
I found the ARP studs at a local shop, but they said I might have to either cut the extra length off the studs or pick up some lug nuts that let the stud stick through. They had the moroso ones too, but I opted for ARP since you recommended them - what did you do?
