I've been struggling with air bag code 34. I have followed the service manual procedure here:
http://ww2.justanswer.com/uploads/AP/apjp02/2012-09-09_031945_code_34.pdf
Assuming a good air bag module, the possible culprits are
- short between circuit 614 and 615
- bad clock spring
- bad air bag
I have a spare air bag, which did not fix the problem, along with an air bag simulator, which also did not fix the problem.
Using an ohm meter, I verified continuity between the air bag clock spring wires from the dashboard connector to the air bag connector.
Finally, I verified that there was an infinite open between circuits 614 and 615 (no short).
Here is my question: the manual tells me to remove a plastic locking wedge from black air back module connector. I do not see a wedge in there, nor did I remove it (that I know of). I read somewhere else that this wedge may ground/short something together. If this wedge is missing somehow, could this cause my problem?
If my clock spring has continuity, could it still be the culprit?
Thanks!
Jason
- bad clock spring
- bad air bag
Thanks!
Jason
