AIR BAG LIGHT??
  • Thread starter Thread starter RUNINAGT
  • Start date Start date Feb 27, 2007
RUNINAGT
237
CHARLESTON S.C.
Feb 27, 2007
  • Feb 27, 2007
My air bag light has been coming on since I purchased car over a year ago. We scanned it months ago and the code was related to a power supply issue.
The light will flash 5 times then pause for about 2 seconds then flash 2 more times. Then it pauses for about 5ish seconds???
What is the issue here, and if it is a power supply issue where should I start looking?
Thanks for your reply's.
RUNINAGT
237
CHARLESTON S.C.
Feb 27, 2007
  • Feb 27, 2007
Code 52 If I remember right?
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Feb 27, 2007
  • Feb 27, 2007
Check out this site for your airbag issues. It gives you all of the codes, so you can find out what exactly is going on.
1990Coupe
1,462
132
114
Toms River NJ
Feb 27, 2007
  • Feb 27, 2007
more then likley the clock spring in the column is shot. they tend to go bad. thats whats wrong with mine and my airbag light flashes
RUNINAGT
237
CHARLESTON S.C.
Feb 27, 2007
  • Feb 27, 2007
If the clockspring is broke, then the horn and cruise wont work, correct??? Mine seems to be working fine, well at least the horn does. Last time I checked the cruise it worked fine as well.
RUNINAGT
237
CHARLESTON S.C.
Feb 27, 2007
  • Feb 27, 2007
thanks I went there earlier and it does not give for the 1993. Im sure the 91-92 are the same though , also I could not find the code 52, if thats even a code?
1990Coupe
1,462
132
114
Toms River NJ
Feb 27, 2007
  • Feb 27, 2007
you know i think your right. and my horn works dammit!!!! lol
I
iwashmycar
20+ Year Stangneter
Apr 7, 2004
1,236
Columbus, Ohio
Feb 27, 2007
  • Feb 27, 2007
mine was flashing a code 3. The site said something about a power supply voltage, but what i did was put some electrical tape over the sensor mounting bolts and it stopped! I think it was grounding out on the hood prop rod and hood, but i dunno. I was amazed it was such a simple thing. I guess I need to go get some better grounding bolts.
Just my experience lol
adam
Sompin2do
59
TX
Feb 27, 2007
  • Feb 27, 2007
Mine was doing the same thing, but if I remember correctly the horn and cruise still worked. Ended up spending about $500 at Ford to get it fixed. At the time it seemed like nobody but the dealer had a clue in Vegas.
RUNINAGT
237
CHARLESTON S.C.
Feb 28, 2007
#10
  • Feb 28, 2007
  • #10
What was it? Do you remember?
Sompin2do
59
TX
Feb 28, 2007
#11
  • Feb 28, 2007
  • #11
It was a bad clock spring. Good luck.
Mike
1990Coupe
1,462
132
114
Toms River NJ
Feb 28, 2007
#12
  • Feb 28, 2007
  • #12
so the clock spring can be bad and the horn still work? cause im under the impression that if the clock spring is bad the horn could still work
superhuaman
907
Harrisburg, PA
Feb 28, 2007
#13
  • Feb 28, 2007
  • #13
yes, the airbag part of the clockspring is more fragile than the horn/cruise part and is quite separate.
Saleen0679
876
24
49
Yakima, WA
Feb 28, 2007
#14
  • Feb 28, 2007
  • #14
Code 52 shows 'Intermittent or Repaired Lost Battery Feed'
http://www.kwiksgarage.com/tech/air_bag_diagnostic_information.htm
BigHairyMonkey
411
Houston (Bellaire) TX
Mar 19, 2007
#15
  • Mar 19, 2007
  • #15
hmm my airbag light is intermittently flashing and my horn + cruise doesn't work and i couldn't figure out why. so i guess its the clockspring? how much am i looking at to replace it?
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
9
1997 gt Starts then dies a few seconds after.
  • 97orange
  • Aug 13, 2026
SN95 4.6L Mustang Tech Aug 17, 2026
97orange
9
Progress Thread Hello from Nashua, NH
  • sevenup
  • Oct 27, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 28, 2026
sevenup
