  • 1994 - 1995 Specific Tech
AIR BAGS
  • Thread starter Thread starter BREWTUS428CJ
  • Start date Start date Nov 6, 2008
BREWTUS428CJ
66
Lake Elsinore, CA
Nov 6, 2008
  • Nov 6, 2008
Tired of driveshaft rubbing on ebrake cables during turns, I ground down the bracket so that clears great, but the cables still rub, tried messing with the location of the cables, cant make anything work. Ride height was supect, So I measured that and the car is actually 1/2" lower in the back than it is in the front. This is more than likely due to the aftermarket stereo junk I have in the trunk, which is pretty much worthless for anything else now, so I'm going to attempt to raise the rear up about an inch or so, with some air bags. Anybody ever tried it? any downside? I thought this sounded better than getting new springs, and definitely sounds better than removing my kickass stereo. so whatcha think?
Chythar
Recently finished repairing my rear
20+ Year Stangneter
Aug 26, 2004
2,374
140
113
Foothill Ranch, CA
Nov 6, 2008
  • Nov 6, 2008
Never used airbags, but you should be able to raise the rear some by rotating the rear springs. The bottom end of the springs is supposed to point to the driver's side; you can rotate the springs 180, which means the spring ends are pointing to the driver's side. I don't know if this will give you enough of a boost in ride height, but it's certainly cheaper than airbags.
If you want a shorter ride height than the 180' rotation, rotate the springs until the spring end points down.
If you do try rotating the springs, make sure both spring ends point in the same direction or your Stang will be lopsided.
G
In expensive ceramic coating
  • gray owl
  • Jul 12, 2026
  • Mustang Sound & Shine All
Mustang Sound & Shine All Aug 18, 2026
NotaVegetarian
N
Resolved Electrical mayhem
  • 2000ElectricGreen
  • Mar 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 4, 2026
2000ElectricGreen
Tightening upper control arm bushings at ride height dilemma… need some help
  • AnthonyA1234
  • Dec 27, 2024
  • 2 3
6K
Fox 5.0 Mustang Tech Feb 27, 2025
General karthief
M
  • mnky99
  • Sep 5, 2025
mnky99
M
Did an auto reset procedure earlier, few questions
  • from6to8
  • Jun 19, 2024
1994 - 1995 Specific Tech Jun 19, 2024
from6to8
