air fuel gauge hookup help
  • Thread starter Thread starter surfandturf
  • Start date Start date Apr 7, 2009
surfandturf
10
Cincinnati, OH
Apr 7, 2009
  • Apr 7, 2009
What wire is the return signal on the eec for a 89-90 stang? can not find on mitchels1 since registered as an 87
bubba-dough
1,044
Indiana
Apr 7, 2009
  • Apr 7, 2009
Auto Meter
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Apr 7, 2009
  • Apr 7, 2009
The A/F gauges that use the O2 sensor signal will jump all over the place. The reason is that the O2 sensors "switch" between .2 volt lean and .6 volt rich with a curve that looks like the drop off a high cliff. The curve is almost straight up and down, so the voltage shoots from .2 to .6 and back down . again 2 or more times a second at cruse. You won't get much useful information except when the mixture is extremely lean or extremely rich, there is no middle ground.
Use 43 (Dark Blue/Lt Geen wire) or pin 29 (Dark Green/Pink wire ) on the computer. Use Wire tap-ins from Radio shack P/N 64-3052. The computer is located under the passenger side kick panel. That keeps you from having to crawl under the car and make a weather proof splice in the wiring. You can use either one, or run a SPDT switch and use both. Then you can use the switch to select which side to view.
b]See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring Mustang FAQ - Engine Information Everyone should bookmark this site.[/b]
Complete computer, actuator & sensor wiring diagram for 91-93 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/91-93_5.0_EEC_Wiring_Diagram.gif
AutoZone wiring diagrams
For 79-88 model Mustangs
http://www.autozone.com/shopping/repairGuide.htm?pageId=0900c1528004e28c
For 89-93 model Mustangs
http://www.autozone.com/shopping/repairGuide.htm?pageId=0900c15280069677
For 94-98 model Mustangs
http://www.autozone.com/shopping/repairGuide.htm?pageId=0900c152801f5e3b
For 1999-2005 model Mustangs
http://www.autozone.com/shopping/repairGuide.htm?pageId=0900c152801ef7d7
Engine Fuel not pumping
  • Creomod
  • Apr 13, 2026
  • 2 3
2K
Fox 5.0 Mustang Tech Jul 22, 2026
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
D
Fuel Erratic Fuel Pressure 1985 GT
  • DienstXIV
  • Jan 14, 2026
Fox 5.0 Mustang Tech Jan 16, 2026
AeroCoupe
C
4375 auto meter air/fuel gauge
  • Canadianfox
  • Jul 27, 2025
  • Digital Self-tuning Forum
Digital Self-tuning Forum Jul 27, 2025
Canadianfox
C
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
