Air/fuel ratio guage
  • Thread starter Thread starter cdiehl30
  • Start date Start date Nov 11, 2007
C
cdiehl30
  • Nov 11, 2007
I have an 88 gt and have converted it to mass air if this hepls answer the question....How do I hook up an Air/fuel ratio guage?
HISSIN50
34
129
Nov 11, 2007
  • Nov 11, 2007
Narrowband goes to one or the other HEGO signal wires (check your EVTM to confirm which terminals in case they are different than the commonly-posted A9* terminals). You can use a switch to toggle between both banks.
If you have a WEGO, post up for specifics.
Good luck.
C
cdiehl30
  • Nov 12, 2007
Thanks...What do you mean by WEGO?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Nov 12, 2007
  • Nov 12, 2007
WEGO is a Wide band Exhaust Gas Oxygen sensor. Wide band sensors are not used in the stock computer because they are not compatible with the computer's programming. The stock computer uses a narrow band sensor.
The A/F gauges that use the stock O2 sensor signal will jump all over the place. The reason is that the O2 sensors "switch" between .2 volt lean and .6 volt rich with a curve that looks like the drop off a high cliff. The curve is almost straight up and down, so the voltage shoots from .2 to .6 and back down . again 2 or more times a second at cruse. You won't get much useful information except when the mixture is extremely lean or extremely rich, there is no middle ground.
Use 43 (Dark Blue/Lt Geen wire) or pin 29 (Dark Green/Pink wire ) on the computer. Use Wire tap-ins from Radio shack P/N 64-3052. The computer is located under the passenger side kick panel. That keeps you from having to crawl under the car and make a weather proof splice in the wiring. You can use either one, or run a SPDT switch and use both. Then you can use the switch to select which side to view.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host)
http://www.veryuseful.com/mustang/t...91eecPinout.gif
AutoZone wiring diagrams
http://www.autozone.com/servlet/UiB..._us/0900823d/80/16/71/3c/0900823d8016713c.jsp for 79-88 model cars
http://www.autozone.com/servlet/UiB..._us/0900823d/80/19/59/5a/0900823d8019595a.jsp for 89-93 model cars
http://www.autozone.com/servlet/UiB..._us/0900823d/80/1d/db/3c/0900823d801ddb3c.jsp for 94-98 model cars
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
Drivetrain 5th Gear Ratio
  • PonyGTrider
  • Dec 8, 2025
2K
Fox 5.0 Mustang Tech Dec 31, 2025
Qtrhrse23
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
