Eh,yea you need to lean it out a bit....
You will probably get like a 14.5-15:1 for cold idle,13:1 for warm.
For WOT on juice you want 12-11.5:1,but the motor tune changes a little when the juice off as when its activated it can mess with the carbs booster signal (so you will need to paly around little here and find out what your carb likes best when off bottle and on bottle as far as FP and jetting).
Also,nitrous engine generaly richen up at the top end,so 10:1 is normal (at end of rpm range,WOT).
