  • SN95 4.6L Mustang Tech
Air in brake lines
  • Thread starter Thread starter Twisted01GT
  • Start date Start date Jun 29, 2005
T
Twisted01GT
56
Joliet,IL
Jun 29, 2005
  • Jun 29, 2005
I changed my front brake lines the other day, along with all my pads. Now I dont get any pedal feel. I can still spin the front rotors with the pedal engaged. I have run about 6 bottles of brake fluid thru and still get some air comming out. All lines have been checked or removed and reconnected, nothing works. Any ideas?
jeffnoel
1,638
Clovis, CA
Jun 29, 2005
  • Jun 29, 2005
How are you bleeding the brakes, starting with wheel furthest from the master cylinder to closest?
hotrodnut
672
North Florida
Jun 29, 2005
  • Jun 29, 2005
How are you bleeding them? Using a Mighty Vac or the buddy system?
MT1083
1,033
Charlotte, NC
Jun 29, 2005
  • Jun 29, 2005
Did you bleed the master cylinder? If you didn't, give that a try.
T
Twisted01GT
56
Joliet,IL
Jun 29, 2005
  • Jun 29, 2005
I started with the passenger side rear, drvr rear, pass front and finally driver front. Using the buddy system. Think a mighty vac would work? should I try bleeding the master?
R
rjstaaf
1,310
Somewhere
Jun 29, 2005
  • Jun 29, 2005
I would try bleeding the master cylinder first. The mighty vac isn't gonna work any better than the buddy system.
Did the master cylinder go dry at any point when you were bleeding or when you were installing the lines?
StangPro
441
Roseville, MI
Jun 29, 2005
  • Jun 29, 2005
If you just did stainless lines, and did them right bleeding the master (which is near impossible on the car) is a waste.
Take a soft faced hammer and whack the snot out of each caliper as you're bleeding it. The fronts are notorious for getting air pockets that have to be whacked out.
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Jun 29, 2005
  • Jun 29, 2005
did you get air in the Hydraulic Control Unit for the ABS? if you did that will make it impossible to bleed without an enhanced scan tool.
T
Twisted01GT
56
Joliet,IL
Jun 29, 2005
  • Jun 29, 2005
Are there any easy ways to bleed the master? As far as I know the master never went dry. I read one post that said the guy was able to get enough pressure to get the car up to speed on a gravel road to activate the ABS and that was enough to get the air out of the unit. Most of the mech's I talked to said it was inprobible but not impossible to get air in the ABS unit. I am willing to try about anything at this point.
WhiteStang
125
Beaufort SC
Jun 30, 2005
#10
  • Jun 30, 2005
  • #10
There are 2 bleeder valves on the side of the master cylinder just below the fluid resevoir......1 front 1 rear....You bleed them just like you bleed you brakes...
G
2019 GT Line lock
  • gray owl
  • Jul 18, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Jul 25, 2026
gray owl
G
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
Brake pad and rotor upgrade
  • Sparky714
  • Aug 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Sparky714
Brakes Front Brake Hardline Routing
  • 93Nifty
  • Sep 11, 2026
Fox 5.0 Mustang Tech Oct 11, 2026
limp
Front brakes not releasing
  • Boats90GT
  • Sep 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 25, 2026
Boats90GT
