Air in brake lines
Twisted01GT
56
Joliet,IL
I changed my front brake lines the other day, along with all my pads. Now I dont get any pedal feel. I can still spin the front rotors with the pedal engaged. I have run about 6 bottles of brake fluid thru and still get some air comming out. All lines have been checked or removed and reconnected, nothing works. Any ideas?
I would try bleeding the master cylinder first. The mighty vac isn't gonna work any better than the buddy system.
Did the master cylinder go dry at any point when you were bleeding or when you were installing the lines?
If you just did stainless lines, and did them right bleeding the master (which is near impossible on the car) is a waste.
Take a soft faced hammer and whack the snot out of each caliper as you're bleeding it. The fronts are notorious for getting air pockets that have to be whacked out.
Are there any easy ways to bleed the master? As far as I know the master never went dry. I read one post that said the guy was able to get enough pressure to get the car up to speed on a gravel road to activate the ABS and that was enough to get the air out of the unit. Most of the mech's I talked to said it was inprobible but not impossible to get air in the ABS unit. I am willing to try about anything at this point.
