  • SN95 4.6L Mustang Tech
air intake temperature
  • Thread starter Thread starter vipergt
  • Start date Start date Jul 15, 2005
1 of 2 Next Last
V
vipergt
47
  • Jul 15, 2005
Does any one know what there air intake temp is (IAT)? Mine is 130F with fipk seems kind of hot to me.
Superhereaux
chicks make me feel inadequate
538
South Texas
Jul 15, 2005
  • Jul 15, 2005
how'd you come up with 130?
seems pretty normal to me. keep in mind the engine is running around 190-200* so 130 is nice and cool by comparison.
what is modified on your fipk?
V
vipergt
47
  • Jul 15, 2005
I have a data logger on the diablo predator and the AIT was 130 after a 25 mile trip and sitting still. The modified part is just the stock tube because my fipk tube melted I made a tube out of pvc and heat resistant paint, but I got the IAC hole and the other hole a little out of kilter so I took it off because it was way close the coil and injector wiring. To lazy to make another for no noticable gain. Plus the stock tubing put the filter in the perfect spot next to the fender hole. That data logger is neato. But it will make you worry about things that may not be a problem. Like its showing me a misfire (another post).
KronicRacer
502
puttering around Ft Lauderdale, FL
Jul 16, 2005
  • Jul 16, 2005
your FIPK melted!! holy hell!!
im glad ive got carbon fiber then LOL
ill run the data logger on my predator today and see what she pulls. it rainy out right now so that may affect the temps.
M
Mustangl3
242
willow grove, pa
Jul 16, 2005
  • Jul 16, 2005
I dont know where you live but here in southeastern pa the hottest i've seen mine is like 120 but after i start moving it usually goes down to around 100 or in the 90s i cant really remember. And that was when it's about 90 outside
DBMSTNG
I fantasize about it being BIG!
2,120
not quite here
Jul 16, 2005
  • Jul 16, 2005
does the FIPK go into the fenderwell? if not, that's the problem. the temp should be around 100*
SigmaPride
170
  • Jul 16, 2005
When I'm driving at a decent speed say 50-60 mph the IAT gets to somewhere within 10 degrees of the outside air temp... usually pretty darn close to it actually. When sitting...it will heat up over 100. Just make sure that when moving it gets somewhere close to outside temp...otherwise your car may be pulling timing due to excessively hot air intake.
I have a JLT RAI, btw.
V
vipergt
47
  • Jul 16, 2005
Thanks guys thats been helpful. I think I will take the fipk off when I can find a stock air box. If anyone has one let me know please. Or I may find a fendermount cai. I thought that was a little hot. Oh the tube did not melt all the way, more of a deforming from the heat. I do not recommend engine bay mounted filters. I thought I would measure IAT because it runs good in the morning but when it gets hot, its a dog. Even after 15 miles in the morning I feel a sluggishness.
KronicRacer
502
Jul 16, 2005
  • Jul 16, 2005
90* out today. it felt hotter than that.
i did city and highway driving in the city it would reach as high as 140*F in stop and go traffic. on the highway it went as low as 108*F 70-75mph.
the radiator was running at 189*F
KronicRacer
502
Jul 16, 2005
#10
  • Jul 16, 2005
  • #10
check your pm in a bit
V
vipergt
47
#11
  • Jul 16, 2005
  • #11
Thanks for checking that with your pred
hotmustang331
2,967
Bastrop,TX
Jul 16, 2005
#12
  • Jul 16, 2005
  • #12
Man, thanks for the post! I was wondering what that thing was showing normally...so now that I see it shows 100-140, I cant imagine how much timing the EEC is pulling. Thats exactly why I bought a kit last week to relocate that into the fender. Hopefully it will help.
V
vipergt
47
#13
  • Jul 16, 2005
  • #13
just got back from going to the store 10 mi and it was running 142 @ night. crap!
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Jul 17, 2005
#14
  • Jul 17, 2005
  • #14
yeah i am going too relocate mine too the inner fender too. then it will get nice cool air when at the track with the headlight pulled.
J
Jakes
84
#15
  • Jul 17, 2005
  • #15
Now you know why Ford go's to all that trouble and expense to install a thru the fender air intake as stock. AND... why when changing to a free flowing CAI you should always get one that go's thru the fender and doesn't suck in that HOT under hood air.
V
vipergt
47
#16
  • Jul 17, 2005
  • #16
thanks jakes you were right
KronicRacer
502
Jul 17, 2005
#17
  • Jul 17, 2005
  • #17
this is what i want to do with my intake . put a heat sheild wrap on the airbox, maybe the tube also . if i do ill get it on the 25th when i get my subframes
http://www.steeda.com/store/-catalog/HeatShield.htm
every little bit helps
ESVA
Jul 17, 2005
#18
  • Jul 17, 2005
  • #18
Personally i would not relocate the iat senor into the fenderwell, your tricking the eec to think the air temp is cooler than it actually is getting. more prone to detonate
V
vipergt
47
#19
  • Jul 17, 2005
  • #19
I believe he is talking about the air filter not the sensor
KronicRacer
502
Jul 17, 2005
#20
  • Jul 17, 2005
  • #20
http://www.svtperformance.com/forums/showthread.php?t=174320
check out this link , it may be just for cobras intake it may apply to the gt
1 of 2 Next Last
Explorer intake vacuum port
  • JD1964
  • Oct 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 29, 2026
Mustang5L5
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
Ambient temperature sensor
  • 2003 mustang gt
  • Jul 11, 2025
SN95 4.6L Mustang Tech Jul 11, 2025
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
M
Idle problem
  • miser143
  • Oct 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 11, 2026
CAMTWO1070
