Air Ony Discharges From Defroster Vents: All Lines Connected And Intact
No hiss when selector is positioned between floor, def, vent, mix, etc.
I get a few pumps of the power brake via vacuum stored in canister when engine is off.
I followed the lines under the hood that run from pass firewall to passenger side vacuum tree, to across the firewall to the power brake booster vacuum tree.
Looks good under the dash. Connected and intact.
Now What?
If you have some vacuum tube lying around, try swapping it, you may have a crack somewhere hard to see. Try to open the vents manually (under the glove compartment), see if they stay. I wonder if testing using a vacuum cleaner would work or potentially do damage...
I was looking through my service manual earlier about this, and was thinking your defrost vacuum motor was stuck, but if that was the case you should still be able to get air on the floor vents as well depending on what you have it set to. I would assume a vacuum leak some where in the control, or maybe a clogged port on the control valve.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring http://www.veryuseful.com/mustang/tech/engine/ Everyone should bookmark this site.
Ignition switch wiring
Complete computer, actuator & sensor wiring diagram for 91-93 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/91-93_5.0_EEC_Wiring_Diagram.gif
Vacuum diagram 89-93 Mustangs
HVAC vacuum diagram
TFI module differences & pinout
Fuse box layout
